S2 pulling to right when accelerating
Old Jan 14, 2006 | 01:30 PM
Hrsturbo's Avatar
Hrsturbo
Default S2 pulling to right when accelerating
It started today, put my foot down and as soon as a bit of power started coming on it pulled to the right like crazy, also pulls to left if changing down a gear at high revs.
Would this be my gearbox or is there any other explanation?
Only just got the neq box in from gearbox man which is stage one and not really give it much so bit confused.
Help
Old Jan 14, 2006 | 01:38 PM
DanRSturbo's Avatar
DanRSturbo
Touque Steer ??
Old Jan 14, 2006 | 01:40 PM
Hrsturbo's Avatar
Hrsturbo
no it nothing like that because it wasn't doing it earlier, just started today!
it really pulls hard when your in a straight line, more when your at lower speeds
Old Jan 14, 2006 | 01:46 PM
dave1982rst's Avatar
dave1982rst
i use to have something like that, turned out it was the anti roll bar not tightened / worn bushes
xr-stu's Avatar
xr-stu
sounds like badly worn bushes. check the engine mounts aswell.
Old Jan 14, 2006 | 01:49 PM
GVK's Avatar
GVK
I had that happen on my old Series 2 was the Inner TCA bush on one of the TCAs.
Hrsturbo's Avatar
Hrsturbo
will check to see if its come loose but it really doesn't feel right, it keeps wanting to spin in 3rd when its not even running big power
does anti roll bar help tighten it up and stop spinning as well?
Old Jan 14, 2006 | 01:50 PM
xr-stu's Avatar
xr-stu
chances are its the bushes mate, dont fret through its hardly a major job.
Old Jan 14, 2006 | 01:51 PM
Hrsturbo's Avatar
Hrsturbo
sounding like bushes then
any easy way of checking?
cheers
Old Jan 14, 2006 | 02:09 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I was going to say bushes too, if that helps.
See if they are cracked badly, and just for general signs of wear. Likely to be knackered if they are original.
Old Jan 14, 2006 | 02:13 PM
NUTS RuS's Avatar
NUTS RuS
Poke and lever around with a metal pry bar.
Somethings lose or worn or the tracking / camber is out on one side.
Old Jan 14, 2006 | 02:18 PM
saffsta's Avatar
saffsta
I agree with what everyones saying mine did exactly the same thing for the same reason due to badly worn bushes and worn engine mounts
Old Jan 14, 2006 | 02:24 PM
Thrush's Avatar
Thrush
Irritating c........
Yup, same happened on my mk4 3i - was front ARM bushes. Could also be TCA bushes as suggested or ball joint on one side, which can throw tracking out.
My mk5 does it at the mo cos the ball joints are fooked and tracking keeps getting chucked out - cept mine does it the other way around : pulls to LEFT under accelleration and to the right when you lift off or change gear.....
Old Jan 14, 2006 | 02:33 PM
GVK's Avatar
GVK
Just jack it up and pull the wheel about, you'll soon feel any play
Mine was running one of Ahmed's chips @ 16psi and was a bit lively with one wheel wanting to go in a different direction than the other
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
landaqmabba
Sep 15, 2015 07:16 PM
