s2 cold start problems - advice needed
Old Jan 13, 2006 | 08:38 AM
andre_k's Avatar
andre_k
Default s2 cold start problems - advice needed
hi, as some of you may have read, for the last few days i have had a start-up problem on my s2.
in the morning, when i try to fire her up, she starts for a nano secont, then just cranks over....
there is no fuel at the injectors, unless i hold the flap slightly open on the metering unit, then she will splutter and backfire for a minute, cutting out or really struggleing to idle. then she will all of a sudden clear up, and all is ok
yesterday stu said he was 100% it was an air leak, but then it was fine so i didnt look... this morning it wouldnt start again, so i will check that now.
why would an air leak cause these symptons? any other suggestions?
any help mucho appreciated
Old Jan 13, 2006 | 09:45 AM
andre_k's Avatar
andre_k
bttt
Old Jan 13, 2006 | 11:56 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Ive got very simmilar problems, i thot it was because my car doesnt get used often, but when it does get used it's the same not even when its in the morning, but if its started, left to cool down for a few hours and then it's the same im pretty sure i dont have an air leak aswell
Old Jan 13, 2006 | 12:01 PM
Stu @ M Developments's Avatar
PassionFords Creator
https://passionford.com/forum/viewtopic.php?t=168085
Old Jan 13, 2006 | 12:10 PM
vroooom ptssssh
It Wasnt Me!
Is it possible to tell if their is an air leak by the vacume on your boost guage?
And when my car is running, if I lift the oil cap it sucks it back on, so their must be good vacume - but again will this show if i have a leak?
Car starts if you leave fuel pump priming (bridged relay), press the flap down once, or if cranking and someone holds flap down bout 5mm
runs dog rough when cold, try and rev and it'll cut out, after a minute it's perfect!
And do S1's have the heated seat fuse?
im off to check for that fuse!!!
Old Jan 13, 2006 | 12:45 PM
andre_k's Avatar
andre_k
vroooom ptssssh
the fuse makes all the differance
stu, didnt see the reply before i posted this this morning
Old Jan 13, 2006 | 12:50 PM
vroooom ptssssh
It Wasnt Me!
Aint been out to check it yet, but do i have it?
Old Jan 13, 2006 | 04:40 PM
bigad4x4's Avatar
bigad4x4
Could it be anything to do with the mixture??
Old Jan 13, 2006 | 04:43 PM
vroooom ptssssh
It Wasnt Me!
Dunno bout anyone elses but mine got set up and a week or 2 later it started doing it so cant be that.
Old Jan 13, 2006 | 07:20 PM
andre_k's Avatar
andre_k
so did mine, jamie said it could be the injector seals leaking...
Old Jan 14, 2006 | 03:33 PM
vroooom ptssssh
It Wasnt Me!
Ive just went and checked and it looks like i dont have this fuse!!!
Its meant to go in the fuse box atr the top of the pic, 1 position in from the left. . . where will i get one?
Old Jan 15, 2006 | 01:22 AM
andre_k's Avatar
andre_k
does the fuse bit have the metal contacts for one?
Old Jan 15, 2006 | 01:50 AM
vroooom ptssssh
It Wasnt Me!
Not sure will need to look into it further
https://passionford.com/forum/viewtopic.php?t=168627
Old Jan 15, 2006 | 11:22 AM
S1's dont have that fuse
Old Jan 15, 2006 | 11:23 AM
vroooom ptssssh
It Wasnt Me!
Damn it
Old Jan 15, 2006 | 11:30 AM
Ive replied to your other topic too where that chaps telling you that im wrong....
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Archiejay
Aug 12, 2015 12:07 PM
col93saphcos
Aug 7, 2015 03:21 PM
Tinshaw
Aug 4, 2015 09:16 PM
fatboy billy
Aug 3, 2015 08:34 AM
