causes of misfire on boost help ?
i just got car back and its ok driving on part throttle, but full throttle its missfireing on low boost (18psi). Any ideas anyone ?
Yeh its an RS500, with a T34 hybrid and 200 block low comp motor. The set up was fine before it was reshelled. It sounds like its missfiring/stutters, like it hits the limiter(but it isnt), it doesnt cut out. But it only does this when I put my foot down.
CheeRS
CheeRS
It may be a good idea just to take it to a rolling road and get it checked out incase it does any damage, may be cheaper in the long run
as sed, try closeing plug gap up to say 0.5mm, if still misses try
new plugs (if old)
grpA coil
Leads,
Fuel filter and or pump (can check flow at 3 bar, to see these are at fault)
Wot plugs are you running, and gap?
Wot have you changed since it last run well (no missing)?
new plugs (if old)
grpA coil
Leads,
the plugs are ngks not sure of model as they were fitted by company that built engine and fitted coil pack and omex ecu plugs have done around 2.5k miles will check gaps .
car is runing coil pack and new leads cars got brand new fuel filter and 044 pump with braided lines front to back.
only things ive
changed from full rebuild (full resto/ reshell) engine wise only is 044 pump + braided lines
only things ive
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
