Fuel pipe????
Old Jan 12, 2006 | 05:00 PM
Nick500's Avatar
Nick500
Default Fuel pipe????
Where can I get the tank to fuel pump pipe from? It is a braided stainless pipe with the goodridge ends I am after anybody help or point me to the right people? also what size is it? what gauge?
Thanks
Old Jan 12, 2006 | 05:02 PM
MAD EVO 4's Avatar
MAD EVO 4
I should think you would need -6 gauge and ptfe braided pipe, you get this from demon tweeks or any good motorsport site bro
Old Jan 12, 2006 | 05:10 PM
rscozzysie's Avatar
rscozzysie
have u tried perkatek (not sure if this is spelt write ). they do braided hose's
Old Jan 12, 2006 | 05:19 PM
RichardPON's Avatar
RichardPON
-6 will be far too small from tank to pump on a 3door.
Also depends what pump.
Old Jan 12, 2006 | 06:38 PM
Nick500's Avatar
Nick500
Richard where did you get the pump assembly you had on the track car? do you still have it? it is still the standard pump at the moment!!
Old Jan 13, 2006 | 09:50 AM
RichardPON's Avatar
RichardPON
Nick,
IIRC, the standard pump just has a normal push fit for the hose, and is jubilee clipped?
I source all the fitting parts for that tank to pump stuff myself - will be registering as a trader at some point doing primarily that, but I can certainly advise you in the meantime.
Old Jan 13, 2006 | 11:06 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
standard pump has push on hose connection along with push on onto the tank.
to put aeroquip hose on you will need a 044 pump with comes with a threaded pump inlet and you'll have to mod your tamk with a screw on adaptor.
RichPon was using a alloy tank, not a standard one.
Old Jan 13, 2006 | 11:24 AM
STUCOS's Avatar
STUCOS
Nick try pirtek or hydrosun,surely you should know that
cheeRS stu
Old Jan 13, 2006 | 12:16 PM
RichardPON's Avatar
RichardPON
True mate, but I have supplied a couple of people with 044 pumps in standard position with regular tanks
Old Jan 13, 2006 | 01:33 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
how did you fit the aeroquip to the tank?
Old Jan 13, 2006 | 01:37 PM
RichardPON's Avatar
RichardPON
As long as you use NON-PTFE lined, then you can jubile to the tank, as the hose size is a perfect fit.
By the way, did you ring my mobile earlier?
Old Jan 13, 2006 | 02:19 PM
Nick500's Avatar
Nick500
Thanks guys!!
Stu - I did think about Pirtek but never thought they would have fuel hose as a standard stock item!!
Old Jan 13, 2006 | 02:29 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Yes Rich. Coming up your way tomorrow afternoon to go to Silverstone. Can you pm your address for the satnav or a suitable meeting point.
We'll be coming along the M4. Hope to be by M25 about 17.00 or is that a bad time ?
cheeRS Richie
155lee
Sep 6, 2016 11:10 AM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
