MTX75 Gearbox Mounts, Shafts, Driveshafts
Yes at last we now have 3 piece shatfs for the MTX75 Gearbox to be able to run in a ERST with a S1 Antiroll bar.
So you will have no tourque steer due to the equal outer length shafts.
Better handeling due to the S1 roll bar
A better gearbox all round for ratios, speed etc..
Add this to a big engine build and you have a foooking great setup
All the parts needed for the conversion are modded HIGHLY to be able to use with our setup.
i.e Shafts, Hubs, Brackets, extra shaft and bearings,
The MTX75 box IMO is better then any 15 year old box that is gonna be in a RS.. Or even a rebuilt one!
If you dont want to run the MTX box or the 3 piece shaft...........DONT
Its not made for any other box..........................................YET
Wasn't picking holes in anything mate
I can understand your reasons for using the MTX75. Just wondered about the gear spread and how suitable it was for this particular application.
In what way is it better than say a box from Bernie with a Quaife ATB new main shaft with larger bearings and shot peened gearing?
The age of the box has loads to do with it! I dont want a 15 year old box that has been pushed for power all its life by loads of different owners etc...
At the end of the day you could go and spend loads of money having a box built, but why bother if you can go the better way for less money.
DazC,
plus I wouldn't trust an MTX75 box with the projected power figure of my engine anyway......my box is that spec because I chose it to be that spec (Quaife diff), the only uprated bit about it is the larger bearings....the gears are standard but have just been shot peened while they where out....
now come on , you know theres one being used around your power level daz
Originally Posted by markk
DazC,
The nearest MTX box that could be considered would be out of a Focus RS but not some shonky Mk 5 E'scrote box...
So they never changed anything apart from the diff? My question is, when the old RST box weak point is the reconditioners main shaft bodge, with this point addressed, is it really weaker than an MTX?
The manifold was blowing at the turbo flange. When I took it off and looked at it with a steel rule edge it wasn't flat so needs machining falt again.....not serious I know.
Originally Posted by turbo man
quaife do a 3 piece shaft for a std rst box anyway
Been looking for info etc. but cant find much?
We have no price at this time for the conversion, as it is still getting all the machining and fabrication costs worked out. The price will also change depending on fitment as the Zetec engine has the fittings to start with on the back of the block, where as the ERST/FRST needs a convertor plate.
The conversion parts will inclued everything apart from the gearbox itself.
The gearbox will be available seperatly as sometimes customers can source these for very sensible money without myself having to hunt for a good one and remove etc.
The MTX75 replaced the IB5 didnt it? Id like to know why - is it smoother/stronger? What box is the 6 speed ST170? I'm guessing they're not as strong as that why they not in Focus RS.
Thanks - Sunny.
Think you can find a bit more on them here : http://www.getrag-ford.de/ehtm/prod1.htm
You can pick the boxes up 2nd hand for not too much money however regarding it's ability to take good power...a) it depends on how much power and b) imo there is only one proper way to find out.
Thanks - Sunny.
Thanks - Sunny.
TPM961
15-01-2018 10:50 AM
cossirob
16-09-2015 07:39 PM
