Plumbers.......... and Tiff - a hot water question!
Old 11-01-2006 | 05:04 PM
RichardPON's Avatar
RichardPON
Default Plumbers.......... and Tiff - a hot water question!
Okay, got a problem in my brother's new flat.
The sink in the kitchen for some reason gives out the most piddly little stream of hot water, but all the other taps (bathroom and the en-suite) give out a reasonable flow of hot water.
System is typical new build (i.e. all electric) immersion tank in cupboard.
Recently fitted a new tap and nothing has changed, so I know it's not that.
What could be the cause of such poor pressure and flow at this one particular tap only? Blockage of some sort?
Tiff - you fit showers too? Might need a quote!
Old 11-01-2006 | 05:06 PM
TIFF's Avatar
TIFF
Chasing Radders
Rich
Is the pipework going to the tap very small in diameter????
Old 11-01-2006 | 05:09 PM
RichardPON's Avatar
RichardPON
Not especially.
The pipe work emerging from the wall is that funny plastic variety.
T's off to the washing machine next to the sink with brass stop valves on each pipe and up to the tap.
Cold out the kitchen sink tap runs like a good 'un.........
Old 11-01-2006 | 05:12 PM
TIFF's Avatar
TIFF
Chasing Radders
I asked as sometimes the taps use 10mm connection pipes and this can restrict the flow a little.
Are the stop taps fully open that feed the sink??
Is it a mixer tap set-up or single tap for hot and cold?
Old 11-01-2006 | 05:14 PM
BrianB's Avatar
BrianB
is it a combi, gravity fed or unvented hot water?
Old 11-01-2006 | 05:17 PM
RichardPON's Avatar
RichardPON
Tiff,
Stop taps are open fully, and I know everything is working fine as I swapped everything round the "wrong" way to eliminate everything from that point to the tap.
Single head with hot and cold feed directly to the tap.
Brian - I'd imagine it's a gravity fed system.
Old 11-01-2006 | 05:18 PM
rapidcossie's Avatar
rapidcossie
is it a mixer tap??
Old 11-01-2006 | 05:23 PM
TIFF's Avatar
TIFF
Chasing Radders
Right then Rich...Try this
You may have a slight air lock but this will get rid of it
Put the palm of you hand over the end of the tap spout.....HARD
Open the hot water tap fully and leave it open....with your hand over the end you wont get any water out.
THEN
Open the cold tap fully BUT be careful as if your palm isnt over it right you may get wet a little....
This will force the cold water back up through the hot and as it is mains pressure it will blow any airlocks away.
Let this run for 5 seconds or so.
Then shut off the HOT tap first then the cold.
BECAREFUL moving your hand away as a little water will spray out.
Then open the hot tap on full for a while and see how it is then
Old 11-01-2006 | 05:24 PM
TIFF's Avatar
TIFF
Chasing Radders
PS--I SOOOO wish i was there to watch you do this
Old 11-01-2006 | 05:26 PM
rapidcossie
THEN
exactly what i was thinking!
had to do it for a customer today...worked a treat!
Old 11-01-2006 | 05:27 PM
Snowy_Astra's Avatar
Snowy_Astra
THEN
I see a problem with this.
Us humans only have 2 hands. So how can you open both taps whilst holding your palm over both outlets?!
Old 11-01-2006 | 05:28 PM
TIFF's Avatar
TIFF
Chasing Radders
Tricks of the trade eh
And people wonder why we charge what we do, That is a VERY technical procedure
RichardPON's Avatar
RichardPON
I am so gonna video myself doing this, send it in to "You've Been Framed", and we can all go out on the piss with the £250 they pay for each video!
Will give it a go mate!
TIFF's Avatar
TIFF
Chasing Radders
THEN
That is why you are not a Plumber
Old 11-01-2006 | 05:29 PM
TIFF's Avatar
TIFF
Chasing Radders
DEAL
Old 11-01-2006 | 05:34 PM
rapidcossie
yeah something a plumber showed me a while back
Old 11-01-2006 | 05:36 PM
Snowy_Astra
THEN
So all plumbers have 3 hands? Is it a substitute for your cerebrum? most plumbers who come here seem to leave theirs at home!
Old 11-01-2006 | 05:38 PM
RichardPON's Avatar
RichardPON
Right, well I'll try this and report back
TIFF's Avatar
TIFF
Chasing Radders
Here is a clue
Old 11-01-2006 | 05:39 PM
TIFF's Avatar
TIFF
Chasing Radders
Cant wait
Old 11-01-2006 | 05:43 PM
Snowy_Astra
Here is a clue
*Spence picks up cerebrum*
Old 11-01-2006 | 05:44 PM
TIFF's Avatar
TIFF
Chasing Radders
Old 11-01-2006 | 06:39 PM
Dunccoss's Avatar
Dunccoss
he is probley mopping up water now and allso having to wipe the ceilling and walls dry
Old 11-01-2006 | 06:54 PM
Jamz's Avatar
Jamz
Oooh my kitchen tap is like this, might give it a go
Old 11-01-2006 | 07:47 PM
skillicky's Avatar
skillicky
Old 11-01-2006 | 07:55 PM
TIFF's Avatar
TIFF
Chasing Radders
I SOOOOOOOOOOOO hope he has some pics
Old 11-01-2006 | 08:04 PM
rsrob's Avatar
rsrob
does this work on mixer taps ?? because every so often my shower doesnt work
i think the shower pump draws in air when closing the bathroom tap for some reason, because ocasionally when turning off the mixer tap you hear the pump turn on for a second
Old 11-01-2006 | 08:07 PM
JxBabe's Avatar
JxBabe
I reckon Tiff's just making it up just to laugh at Pon when he comes back on here complaining because he's sopping wet and the taps still don't work
Old 11-01-2006 | 08:08 PM
TIFF's Avatar
TIFF
Chasing Radders
SSSSSSShhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Old 11-01-2006 | 08:12 PM
The Rapid 1's Avatar
The Rapid 1
OR couldve perhaps mentioned linking the washing machine feeds together
BUT as said not nearly as much fun
Steve
Old 11-01-2006 | 11:07 PM
Lee Reynolds's Avatar
Lee Reynolds
This is for mixer taps mate!
Old 12-01-2006 | 12:28 AM
CHRISP's Avatar
CHRISP
putting one washer hose across both washing machine valves is the easiest way ,and less mess (only if you have two valves as most new washers only need cold water inlet ...so check first )
richard you say the system is a new style flat set up with an electric immersion ....how high off the floor is the hot water outlet (pipe)on your hot water storage tank (or cylinder )if it's only about 4 or 5 foot (ish)..your never going to get great water pressure as the system doesn't have enough head (height to create gravity fed pressure )it will always loose pressure on horizontal runs as well.... so how far away is the hot water storage ??
Old 12-01-2006 | 11:21 AM
RichardPON's Avatar
RichardPON
Chris - I should be able to posts some pics up later.
Old 12-01-2006 | 11:31 AM
Redeye Jedi's Avatar
Redeye Jedi
Bit like the much loved IT solution....
Switch it off and on.... That'll be £40 please!!
01-11-2015 07:53 PM
Mark RS
12-10-2015 07:01 AM
DAZZER
30-09-2015 09:43 PM
Quick Reply: Plumbers.......... and Tiff - a hot water question!
