sorting my shed out, need heat in there
any ideas on best way to do it?
have got power down there, gonna use something like expanding filler foam to cover the gaps in the roof, but what kind of heater do i need?
any ideas greatfully received!
I got a fan heater in mine mate as heats real quick. tried a oil filled rad 1 mate but takes a while 2 heat up.
I only paid a tenner for my fan heater with thermal cut out wen it gets 2 ur temp u want.
hope this helps
hope this helps
An oil filled radiator in a wood shed would be pointless. The insulating qaulities of the wood on a shed are like non existant! You either need to board it out inside and isulate it, then a oil rad would be ok as the heat would build up, or get a heater more substantial. But the latter is not energy efficient and wastes money...niether of which are any good really!
Same with Spax. An oil filled rad i dont really advise for a garage. They are quite slow releasing heat, and it takes a while to build up. In a garage this will easily get lost around the door area.
YOUR NOT TRAINING HARD ENOUGH IF YOU NEED A HEATER!!
start training, get all sweaty, then you don't need a heater, you'll be warm enough, lol
number #1 ingredient for pneumonia
was thinking the same thing
Well, insulation is the obvious solution to heat loss! It will pay for itself in what you save, but only over time! Best way in a garage would be to fix 'kingspan' insulation boards to the walls and then ply over and then rockwool in the roof space. But it all depends on what type of garage you have. Then a thick curtain at the door! If your that bothered
Oil rad would be fine than on a constant low setting
my garage has a decent door thats insulated and sealed all the way around and cavity walls and insulated in the loft
Hopefully an oil rad will work ok then!
Just had a concrete sectional garage built and looking to insulate it. been told to put a polythene membrane before fitting any kind of insulation.Dont know if this is right so some advise would be gratefull.
cheers. tim
cheers. tim
Depends on what kind of insulation you use. If you use a foam kind like kingspan it would be ok without a membrane, but if you want to use rockwool then you must use a membrane too!
cossie09
10-09-2015 06:56 PM
