1.3 gearbox for an xr2 engine
Old 09-01-2006 | 04:35 PM
Rs Dave's Avatar
Rs Dave
Default 1.3 gearbox for an xr2 engine
would i have to change the driveshafts to 1.3 shafts for me to put a 1.3 gearbox onto a 1.6 xr2 engine and will it fit and will the clutch fit??
Old 09-01-2006 | 05:03 PM
xr-stu's Avatar
xr-stu
aslong as the car isnt a facelift (86-)and the gearbox from a pre facelift (-86) itll all bolt up fine and dandy with youre original clutch and driveshafts.
if the box is from an early car and the xr2 is a late mdel you'll have to find an early linkage.
thinking about it, they didnt make any 1.3 after 86, they changed to 1.4! so if yours is D/E or newer, you'll need an early linkage!
Old 09-01-2006 | 05:11 PM
Rs Dave's Avatar
Rs Dave
cool thanks for that...the thing is the engine is in a mark 4 escort and i have no idea the age of the engine... so....lol hard question really
Old 09-01-2006 | 05:18 PM
xr-stu's Avatar
xr-stu
well look on the gearbox and there should be a long part number starting with 81 or 86, if its 81 then you'll need an early type linkage, if its 86 you should be alright (if your car is a later xr2?)
Old 09-01-2006 | 05:34 PM
Hardeep_Singh's Avatar
Hardeep_Singh
I have an xr2 g'box which works perfectly fine which you can have if you want, give us whatever you want for it! its from a d plate!
SmudgerByName
52
28-07-2016 07:14 PM
3drRich
13-09-2015 08:32 PM
Ben26
27-08-2015 09:56 PM
Bobby9779
11-08-2015 07:47 PM
wheelwizardrefurbs
04-08-2015 07:23 PM
Quick Reply: 1.3 gearbox for an xr2 engine
