Electrical water pumps?
std pumps sap lots of power! my boss does stock car racing and they dont use radiators or waterpumps but steam systems, dunno how they work but it takes out the pump and he recons it does make a difference....
ive thought about it a little bit mate, can get an electric pump from demonthieves for about 130 quid iirc!
Davies Craig one here (plus controller)
But it can't sing lol
It runs on after engine shut down to keep cooling the engine to take heat soak from the manifold away from the head.
Its fully controlable with engine temperature, so varies the amount pumped when cold or hot etc.
Increased Bhp by just over 5%
Thanks NUTS
I'm going to be fitting a GRS soon and there has been bad storys of RS Turbo cars over heating with big intercoolers
I was told the electrical pump will help it keep cool
)you will increase BHP simply because you have taken another LOSS from the system,, do you get the same pumping flow rates from these units as a water pump tyrning at High rpm? (i was going too try and work out a average gearing from crank pully too water pully but i cant be arsed )
what if something goes wrong with the pump controller? how expensive to replace?
whenever the engine is rotating so is your water pump (well unless the belt as come off, impellar loose)
The gain comes from like you say - removing the losses.
Same reason as race cars don't run alternators etc. But that was not my goal.
Don't forget mine is a K series, prone to doing head gaskets etc (in fact 1 in every 500 competition miles). This has been linked (but not proven) to be connected with the water system, so for me it has to be trialled.
Its now shifting more water around the engine in a controlled manor, and the ability to keep it circulating when the engine is not is a great bonus.
It warms up quicker from cold, and cools down quicker when hot.
http://www.daviescraig.com.au/main/display.asp?pid=47
if you havn't already googled it
i can see a gain from moving the water round once engine is switched off,, but too how great this gain is debatable
http://www.daviescraig.com.au/main/display.asp?pid=44
How Prodrive fit them to 600bhp winning Ferrari's
It pumps around the whole system when cold, not just the engine, so the hot spots are actually cooler, than if it had a thermostat.
It constantly monitors the temperature of the water and adjusts the speed to suit.
its will only monitor the temperature at one point of the engine waters system!
the only reason why ferrari/prodrive will run it is because its a race car with tight rules,, any gain is a GAIN too them
there really isnt anything wrong with a normal water pump (well appart form the brake horse power it losses at peak)
ps its good to have a adult debate
For me I refer to the answer I posted earlier Steve
My water temperature sensor is in the same place Gareth, so the ECU knows no different, other than it reacts quicker to the changes.
I only had 1 in there previous to this system remember, so nothings changed other than flow rate / movement of water around the system.
The normal water pump and thermostat housing on the K Series engines is suspected to be partly to blame for their noted troubles, thats why companys like QED do an uprated remote housing for it.
It helps, but not as much as removing the system completely and going all electric.
Power gains were not my intended interest for trying it, but have come as a bonus I suppose.
of course there are gains to be had by fitting an electric water pump, same as there are from electric PAS pumps and the like.
but there aren't that many production cars running electric water pumps yet, whereas there are plenty using electric PAS pumps. that's obviously because there are bigger gains to be had from the PAS as it's a bigger loss in the first place, but even so, with the challenge to constantly reduce fuel consumption and emmisions if it was worth doing then they would.
having said that, they are also more interested in production costs, and mechanical water pumps are obviously much cheaper than electrical ones at the moment.
as gareth says, it's done in motorsport as sometimes any gain is worth having, even if the costs are relatively high.
i have a bosch electric water pump, but will only use it for the coolant circuit for my chargecooler.
