Gearbox or Auto Eng people
hi peeps, have got my Automotive Eng exam on wed and going through the past exam questions...looking through my notes there is nothing about gearboxes so was just wondering if you could give any help with the following questions:
with question b, is it refering to gear types like helical, semi helical etc, or is it referring to the box type?
and im clueless about how to go about C D and E
can anybody help?
can anybody help?
wheres your pic of the box ? thats just the diff , if the 4th gear is 1:1 the drive is straight through the box
b, helical, semi helical, straight cut ? is that what they want ?
c 130/0.4*105=220nm ?? would be a guess tbh without lookint through my old data
d 1- pinion
2- planet gear
3 - cross pin
4 - sun gear
5 - speedo drive gear
6 - speedo drive pinion
7 - crownwheel
i'll do the last one in a bit !
d 1- pinion
2- planet gear
3 - cross pin
4 - sun gear
7 - crownwheel
eek
its only been a year and im so out of it...
yeah youre right with b)
i'd go straight - no side loads, noisy, high wear (I think)
semi helical - thrust loads,
double helical - quieter, expensive to produce, even wear
you need some gear ratios to work out E I think but you would do it using the outside wheel as the inside will be spinning slower?
cheers for the replies...looking through the paper thats all the info they have provided us with...nothing more
are the above answers def correct?
bassboy
bassboy
the answer to E - 391
406/376 = 30 /2 ( each sun gear ) = 15 + the slower running wheel (376) = 391, 406 - 15 = 391 crownwheel speed is 391rpm
helical gears have a greater sruface area than straight cut, semi helical have a reduced side loading but are noisier, straight cut have no forces outward just against the teeth but are very noisy in operation
as for the three shaft diagram dont know if i can draw it on here
server keeps removing my spaces and compacting things - see if writing space help !
ok version 2 !!
ok version 2 !!
it says continued though? so does that mean the paper or just the question?
what level is this mate? ONC HNC or something?
as part C seems a bit odd as there is no reference to the actual size of te friction plate? just the mean? i.e. point its acting on and its only worth 2 marks so must be a simple calc.
i.e. T = Pressure x friction x radius of gyration x number surfaces
so id make it = 130000n/m^2 * 0.4 * 0.105m x 2 (two surfaces on single plate)
and end up with 10.92 KN??
sorry but memory really not good! lol - what notes have you got?
im still not sure on E either lol
Originally Posted by M Brian
mark....
can you explain for me what youve done in E?
if the inner wheel rotates faster than the outer on the turn - ok
the sun gears/planet gears must be equal or the diff would explode let alone not mesh so the calculation must equal both wheels speeds together , just because the car is cornering the crownwheel doesnt speed up - it cant - its meshed with the pinion which in turn is meshed with the selected gear - so imagine the car is in a straight line , divide the highest from the lowest then divide that by two, then equalise the two wheel speeds = 391
sounds good to me - its been many years since ive done all this - and to be honoust you will prob never need it again - typical schooling !
Originally Posted by markk
Originally Posted by GARETH T
wouldnt e be the average of the two? (add them up and devide by 2)
same answer pal - i just like to be technical !!
and isnt d 1- pinion/output shaft as they could be looking for it all!
it does say "identify and name eash of the numbered components" and as the component is a output shaft incorperating pinion, i just thought i would say! and you know how funny college teachers are,,, unless you write down what they have on there piece of paper its a fail
I didnt understand the calc where the 30 etc had came from?
is it simply
average of the 2 speeds and 376+406/2 = 391?
EDIT just read thats exactly what gareth did :cry:
they always did say fully read the question first pmsl
I typically look for a question more difficult than is there... takes me ages to go through simplish questions.. I was looking for final drive ratios etc to work back to mainshaft speeds etc.
oh and billy haynes where the pic is indentical to, item one is simply called the mainshaft! bit vague there I think
is it simply
cheers for the help peeps...sorry aint replied had 2 exams this week so been revising!
Auto one is on thursday now...
thank you all for your help...checking through the notes there are no notes or digrams given regarding the gearbox, or the final drive assembly...
it is a BEng degree im doing in Automotive Engineering Design...however the teacher is annoying as he VERY rarely puts up notes for us and the pics he uses in class are too much to draw in the tim ehe puts it up
i have some other questions if anyone is bored
bassboy
bassboy
BTW does anyone know where i can get a bit more of a detailed pic of the gearbox for question 1a? im sure there should be a picture as well but theres nothing on the paper
bassboy
bassboy
i found these 2 pics in a text book and wondering if they can be adapted to use for the 4speed constant mesh gearbox showing what i want it to?
cheers
bassboy
cheers
bassboy
old haynes manual
thats where they have got most of the pics from! lol
fiesta mk2 or escort mk4 books I used throughout my degree for pics lol
does anyone know anything about steering boxes?
questions states:
A steering gearbox has a force ratio of 7.75:1 if the driver applies a force of 18N with one hand on the steering wheel of 0.5m diameter, calculate the torque at the drop arm...
how do you go about with that question?
bassboy
possibly you should do it radially....
but it will be basically force x distance to get the moment- then multipled up by the force.
quick calc 18 x 0.5 = 9Nm x 7.75 = 69.75 Nm of force at the arm
I think it will be slightly different as its angular movement but I can't remember the calc.
do you not have the IMECH members handbook? has loads of formulas in for this - I can't find mine at the moment as ive recently moved house.
have you done an ONC or HNC before this?
sorry force by radius actually gives you the torque.
it would be the moment I think if it was linear.
calculation still stands just the terminology - hopefully someone else can verify what ive put.
them pics show it perfectly - the top pic and the bottom pic , just engage 4th gear the drive is shown perfectly
as for the steering melv has sorted that for ya pal !!
WWW.PASSIONFORD-SCHOOL.COM
M Brian markk thank you sooooo much for this...appreciate it greatly...i know all of the hands on stuff...its the the fookin theory and the maths that fooks me up BIG style (should be comfortably retaking my tech maths module in summer PMSL)
also have what seems a VERY VERY challenging question regarding hp, fuel economy etc etc if any one can help? or do you just wnna see the hole paper LOL
bassboy
bassboy
Q1A:
4th gear on a 4 speed box, simply connects input shaft to output shaft.
Line diagram is a straight line!
Mechanical Engineering.
I did the majority of what is being asked above on my ONC though, the level of questions on this one isn't going into that much detail, probably because 'bassboys' course focus's on other things rather than the maths of it all.
i.e. with my degree the clutch question would of given the inner and outer diameters of the clutch and you woulda had to do some calculus to differiantite between to the 2 figures to work out the radius of gyration etc etc
cool, i'd like to do something like that one day, just it means moving for me or one hell of a road trip, iirc bristol was the closest place to do automotive engineering at degree level for me.
TPM961
15-01-2018 10:50 AM
