head gasket failure from Detonation ( Data Log added today )
#42
Originally Posted by madevelopments
You water temp was going up before 2 mins, What was the normal running temp.
Mark
Mark
#44
One thing no Ignition angle is showing is your ecu locked.
Mark
Mark
#48
Its very diff to make head or tail of the figs have you got in graph form show boost/Ign/tps/water temp
Mark
Mark
btw ignition is the 15th column along , column starts with 43.6
#51
Originally Posted by leecavturbo
if you look at 2mins & 37secs in ( 2:37.2 ) ,is the moment i knew something was wrong, its like a recurring bad dream lmao . not at any point did i have more than 79% throttle. but what does concern me is the extremely consistent 27deg of air intake temp ! ?
you can see the gearchanges and boost as i drove before![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
http://www.migweb.co.uk/forums/showthread.php?t=244296
![](https://img.photobucket.com/albums/v333/leesturbo/5cfcab91.jpg)
Mark
#52
Mark
![](https://img.photobucket.com/albums/v333/leesturbo/deletethis.jpg)
#53
leecavturbo
Are you sure that is correct as from 11 effectively 0psi to 14 around 14 psi you do not seem to have any Ignition retard for boost, Is there another table somewhere retarding Igintion, You also seem to have lots of Ignition everywhere, Was the timing the same at the crank or has it been offset.
Mark
Mark
