Mpeg/Avi DVD Movies......
no they cant. unless you have a player that supported them (i've got a KISS DP-450)
you can convert the file to DVD format, and then burn it tho
try a program called WinAVI (do a google) its the fastest ive found. should take about 2 hours to convert a movie to DVD format. the just use nero or something to burn it to DVD-Video
Oderint dum metuant
If your dvd player is an cheap asda type one, then chances are it will be svcd compatable.....
If you make sure you download films that are MPEG2/SVCD format, and then just burn the raw data on to a dvd, your player will play them as normal.......no chapters, menu's etc though.
www.videohelp.com
Check that site out, put in the make and modle of your player, and it will tell you what you can/cant play. It also contains guides on how to convert avi files in to compatable files.
www.videohelp.com
This one is my DVD Player.......
http://www.videohelp.com/dvdplayers....arch&#comments
So, if I have, for example, a 700meg .avi file that would normally play in Windows Media Player and I burn that onto DVD, will it play on the DV-444?
I also have PowerDVD Power Director which I have been using to join movies together. I guess if it needs convertng, that will do it?
Oderint dum metuant
Oderint dum metuant
If you can be arse messing around converting files, just buy this player and all your problems will be over.....
http://www.amazon.co.uk/exec/obidos/...816145-7732405
Has played everything ive thrown at it.......no exceptions.
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
