Daft question about a dizzy
Old Jan 1, 2006 | 12:53 AM
kevsrs's Avatar
kevsrs
Default Daft question about a dizzy
Does the dizzy cap actually do anything apart from cover the dizzy?? For example, will changing the cap do anything to help if i need a new dizzy??
Am showing my RS knowledge now
Old Jan 1, 2006 | 12:55 AM
Brookesy's Avatar
Brookesy
the rootor arm sends currnt throughh it to the leads
Old Jan 1, 2006 | 01:09 AM
kevsrs's Avatar
kevsrs
So there's a rotor arm, dizzy and dizzy cap?? I suppose there's no point replacing just one of these then. Is it best to replace all 3??
Old Jan 1, 2006 | 01:14 AM
Brookesy's Avatar
Brookesy
replacve rotor arm ansd cap first before u buy a new dizzy. se if that sollve your prooblem
Old Jan 1, 2006 | 01:22 AM
kevsrs's Avatar
kevsrs
Ok mate, cheers
Old Jan 1, 2006 | 10:51 AM
CosKev3's Avatar
CosKev3
Default Re: Daft question about a dizzy
If thats your best understanding of the dizzy cap m8 make sure you've got someone helping you when you change it
Or your car will be missing/won't start when you swap them over
Old Jan 2, 2006 | 05:47 AM
kevsrs's Avatar
kevsrs
Right you've got me worried now! What is complicated about replacing it??
I'm kinda on my own with this one as i don't know anyone with any better knowledge than me
Old Jan 2, 2006 | 07:53 AM
andymaac's Avatar
andymaac
you must be a tim them does not have a clue
Old Jan 2, 2006 | 08:19 AM
ballin's Avatar
ballin
kevsrs your dizzy controls your spark timing....
if you just replace the arm and cap though its ok
Old Jan 2, 2006 | 09:45 AM
bud-weis's Avatar
bud-weis
Football Cwazy
basically your leads connect to the cap in a specific order in which the engine fires, make sure when you remove the cap that you leave the leads connected to the old one, remove one at a time and transfer them to the new cap in the same positions as they were on the old cap. rotor arm is a simple pull off and push in fitment.
Old Jan 2, 2006 | 10:04 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The most important part about this convo is the fact that no-one has told the guy that after changing the dizzy you MUST! make sure that the advance is correct on the dizzy or you will not only be finding it hard to start or drive but it could also damage the engine.
IMO if you have no idea, get a pro to check the settings once you have finished messing about.
Regards
Old Jan 2, 2006 | 10:15 AM
ballin's Avatar
ballin
thats what i said in a roundabout way Jano
Old Jan 2, 2006 | 11:36 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Regards
i presume he'll just change the cap/arm first and see how he goes, if the dizzy needs changing then as you say it'll need timing up properly
Old Jan 2, 2006 | 10:51 PM
kevsrs's Avatar
kevsrs
Thanks for the replies folks, me and my haynes manual will have a go!
fourth in the spl still hurting then?
Old Jan 2, 2006 | 11:52 PM
sufsRS's Avatar
sufsRS
its a piece of piss changing it just three bolts mate, make sure the dizzy cap is dry when you put it on bit of wd40 does the trick and make sure its times as said above 12 degrees btdc if your running a standard cam
Old Jan 3, 2006 | 09:27 AM
Versus_Creations
Ask me a question!
Wheres the third bolt?
Old Jan 3, 2006 | 09:42 AM
andre_k's Avatar
andre_k
ditto
Old Jan 3, 2006 | 12:34 PM
sufsRS's Avatar
sufsRS
sorry
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
