Escort WRC Wide Track - Hows it done ?
Old 28-12-2005 | 09:30 PM
Kev.H's Avatar
Kev.H
Default Escort WRC Wide Track - Hows it done ?
The WRC cars have a wider rear track dont they My questions 1: how do they flare the rear arch (is it a different panel) Could it be done post paint or is it something that needs doing pre painting and prep 2: is it the rear beam thats different and how 3: whats the benefit
Dunno why im asking just wondered
Old 28-12-2005 | 09:32 PM
DazC's Avatar
DazC
There is no rear beam for a start. It's a parallel arm set up IIRC...
Old 28-12-2005 | 09:36 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
take a look in the resto, rebuilds and project section, there's a WRC escort in there where you can clearly see the rear sus setup
Old 28-12-2005 | 09:40 PM
markk's Avatar
markk
that will be ian's
as for the panelling - i will leave him to tell you how its done
but does look pukka - ive seen his car 1st hand -hmmmmmmmmmmmmmmmmmmmmmmmmm nice
Old 28-12-2005 | 09:45 PM
Rossco's Avatar
Rossco
Wheel spacers!
Old 28-12-2005 | 11:47 PM
Dan's Avatar
Dan
Hasn't Reyland's new one got a WRC beam or something on it?
Old 28-12-2005 | 11:49 PM
DazC's Avatar
DazC
No, there is no "beam" on a WRC car.
Martin has a Group A or a touring car beam probably...
Old 28-12-2005 | 11:51 PM
Dan's Avatar
Dan
Didn't billabong post a pic of something up then saying this is the new 'beam'? lol
I know that the later WRC Escort's had square section arm's or something along those lines didnt they?
Old 28-12-2005 | 11:58 PM
Billabong's Avatar
Billabong
Martin's 'beam' is a Group A item, and is more of a frame type afair iirc.
Old 29-12-2005 | 12:01 AM
DazC's Avatar
DazC
As Bill said, Martin's is a GrpA "beam". The WRC set up has no "beam" at all but a completely different set up closer to a Mk3/Mk4 escort than the origional Sierra/Escort "beam" set up.
Old 29-12-2005 | 12:27 AM
Dan's Avatar
Dan
Ahh I see! Sort of
Whats the difference between GRP A and WRC then, thought they were the same sorta thing? lol
Was I right about using the square arms, think there Magnesium aswell arnt they?
Old 29-12-2005 | 09:43 AM
Tony Ryan's Avatar
Tony Ryan
Wide track only refers to the GpA cars , this is acheived by using the "wider track " rear arms ( Black Tarmac ones like mine ) . The regs for wRC allowed a fully independent rear end that allows full adjustment on tie rods and a mcpherson strut instead of semi trailing arms .
IIRC these are overall 28mm wider than a std track .
Not a great pic but you get the idea
Old 29-12-2005 | 10:41 AM
Kev.H's Avatar
Kev.H
cool info so how is the rear arch done
Old 29-12-2005 | 11:18 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
is not acheived by useing wider track black arms,is achieved by useing a wide track rear beam. .
wrc cars did not have mag rear links.
Old 29-12-2005 | 11:20 AM
MAD EVO 4's Avatar
MAD EVO 4
oh im getting confused now people, will some one save me
Old 29-12-2005 | 11:22 AM
Micky The Finn
Former Sponsor
forget about it,you wont ever need it and wont ever find it,if you do could you justify paying for it?
Old 29-12-2005 | 11:28 AM
DaveEscos's Avatar
DaveEscos
the rear arch is beaten out at the rear, then a cut is made towards the door and the arch is 'pulled' out... then re welded & seamed
Old 29-12-2005 | 11:29 AM
GARETH T's Avatar
GARETH T
when you getting yours done then dave?
Old 29-12-2005 | 11:35 AM
Kev.H's Avatar
Kev.H
thank you Dave so thats why it has to be done before paint cos it sounds like a flocking mission
Old 29-12-2005 | 11:37 AM
DaveEscos's Avatar
DaveEscos
yeah, its deffo not your Sunday afternoon job after footie!
Old 29-12-2005 | 12:22 PM
ian sibbert's Avatar
ian sibbert
There are 5 levels of track for the various grp'a' & wrc escorts...
Grp 'a' gravel spec 1992 - 1993....(red tca's, green arms)
Grp 'a' wide track tarmac spec 1992 - 1994 (blue tca's black arms)
Grp 'a ' super wide tarmac spec 1994 - 1996 (gold tca's Black arms)
WRC Gravel Spec which was the same as a grp'a' wide track tarmac 1994 spec. (narrow lateral links, black tca's, gravel hubs(which are similar but not the same as a grp'a' hub)
WRC Tarmac Spec....(longer lateral links, black tca's and tarmac hubs)
The track is acheived with different tca's, hubs, beams, front x memebers...there are many levels of all these components and matching them can prove frustrating....
As said the major difference is that WRC cars have a cradle and lateral links....
The wrc shells and some later grp'a' cars had the bodywork widened and heightened to increase suspension travel (particularly on tarmac).
The later grp'a' cars were every bit as good as the WRC cars active diffs etc....the only other advantage was the weight....mag arms are still relatively heavy...
Ian
Old 29-12-2005 | 12:30 PM
Dan's Avatar
Dan
Nice on Ian!
Old 29-12-2005 | 12:47 PM
Kev.H's Avatar
Kev.H
Ian thanks top info
Old 29-12-2005 | 12:50 PM
GARETH T's Avatar
GARETH T
think you sorted that issue out ian
Old 29-12-2005 | 01:46 PM
rZVCh46Nv's Avatar
rZVCh46Nv
This may sound like a complete newbie question, but reading up above, i thought the escos used independant rear suspension - similar to what's been described in detail in its 5 variants right?
as for the wings, i was of the impression they were widened due to the widened rear track of the car coupled with the fact it was not a conventional escort chassis, but a sierra item clothed in special escos bodywork.
the vents on the bottom of the rear spoiler of that jenspeed escos are there to pull out the hot air from the boot mounted rear radiator.
Old 29-12-2005 | 02:46 PM
Dan's Avatar
Dan
Correct, but the wings are widened even further on the above Grp A & WRC cars as descirbed above!
As for the suspension, i'm just as confused as you are! HTH
Old 29-12-2005 | 05:25 PM
markk's Avatar
markk
TF Rallyesport
with you on that tim
and i told you all ian would know the specs
Old 29-12-2005 | 05:28 PM
Tony Ryan's Avatar
Tony Ryan
Cheers to Ian for the full sp ! Tim youre right of course but youre answer could be mis construed that a wide track beam would give the full effect, i forgot to add that , but of course both work hand in hand . My mods go well beyond the std car shape and are obtained with all sorts of tweeks !
Old 29-12-2005 | 06:49 PM
cosworth1978's Avatar
cosworth1978
An other question about it what does a good set cost and is it still to find in great britain latest model gp a 1994 till 1996 super wide tarmac spec
Because i want to buy it this summer to give me a indication.
Kind regards Oscar
Old 29-12-2005 | 06:59 PM
ian sibbert
Oscar....
It is still available in U.K. but becoming hard to find...some super wide track tca's and shafts etc sold on ebay a few weeks ago....
Tim would be better than me to advise on s/hand availability...
You would be well advised to buy a front or rear setup complete of a car as individually the parts add up to a fortune...
Some parts are still available new from Dewitts...
I have all the shaft length, tca, rear arms information (909) part no's etc if you need em....
Regards
Ian
Old 29-12-2005 | 07:22 PM
digita1dragon's Avatar
digita1dragon
Hey Oscar! Have you got any new bits on your engine now since september?
Chris
Vincereese
01-06-2023 10:14 AM
fuzzy
19-08-2015 08:00 PM
Vincereese
18-08-2015 04:57 PM
Vincereese
16-08-2015 07:38 PM
cameron2
10-08-2015 01:14 PM
Quick Reply: Escort WRC Wide Track - Hows it done ?
