what should i expect (bhp wise)
I WENT TO COLLINS A WHILE AGO AND HAD A STAGE 3 FITTED IE T34 WITH -55 HOUSING A SET OF GREYS NEW FUEL PUMP IGNITION COIL AND RUNNING ABOUT 22PSI OF BOOST. SINCE THEN I'VE FITTED A 500 COOLER SO I SUPPOSE MY QUESTION IS WHAT DO YOU THINK IS A SAFE BOOST PRESSURE TO RUN ON THIS SETUP (BARING IN MIND THAT IT LEAVES A BROWN TRAIL FROM THE EXHAUST WHEN I COME ON BOOST AT THE MO) AND WHAT BHP SHOULD I GET FROM THIS SET UP.
How good is Karl SIB? my 3 door was running like a sack of shit when i took it to him, could`nt believe the transformation when he had finished, i would`nt go any were else..............
Originally Posted by Bosch-Man
jimc instead of asking on a website where you will get 101 different answers from resident experts may i suggest you phone Collins?
DEYTUKURJERBS
You got a stage 3 chip in?
Or one actualy suited for greys?
As a stg3 chip is greens, and if you put greys on without a chip for it it will overfuel like a cnut
2Evos & 1 Escort Van :-)
My car runs really well on his chip, although it was also spot on with Stu's chip when on Stage 3 / Greens spec.
Basically you won't go wrong with either of those companies - I'd recommend anyone else to either of them.
Si
Originally Posted by jimc
it aint that bad as they reach the roof but was wondering about upping the the boost a tad to use the fuel being pumped in
You won't go wrong with Karl though, it will be the best mod you ever did
Football Cwazy
you should have it live mapped for defo, with your 500 cooler expect the boost set to peak around 29 and hold 25 ish . speak to Karl about what you want, it's your car and he will do what you ask, but i doubt he'd recommend much more boost?
the smoke could be a number of things really, tired engine or just overfuelling, greys ideally need live mapping so an off the shelf chip isn't really good enough.
power should be a genuine 365-370bhp i reckon maybe slightly more
