Do these work ?
http://cgi.ebay.co.uk/ws/eBayISAPI.d..._BIN_Stores_IT
Its just say if im listning to music my lights will dim
Do they do what they say on the tin ?
What are you meant to do with that? Connect it to the Pos and Neg of the battery? If so, don't bother!
If your lights are dimming then look at your earth return to the battery from the body and uprate it if required. Check the alternator and see if it can handle the current your stereo draws. Check the wiring between the starter main power terminal and the alternator itself and uprate it if required.
do u have any amps running speakers??
if so look into getting a power cap.
these charge up when ur not pulling a large current, and the feed the amp when it needs more current rather than it just using the battery.
it should help the diming.
im not sure if u can only use it with amps, of if u can use it for the main live off the battery.
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
