fao pc techies
fao pc techies
i have a laptop thats just been reformatted. i dont have a restore or driver disc for it. the os (xp sp2) detects that its got a wireless card in it but it doesnt have the drivers. ive no idea what kind of card it is. all the os tells me is "Wireless_LAN_11Mbps_Mini_PCI". how the hell do i find out what it is? and im not opening it up to look!!!!
ditto what everyone else said, what make is the laptop (if the card is std) or you could have a look for a part number also. (itll be a compartment underneatht the laptop, little quare adapter card, looks a bit like a memory module
if that dont work you can get the Device ID from windows and we can work it out from that
ranj/stu, not a brand as such, it was built and supplied by hi-grade
dan, no but as its an old machine (2 years old) the sp thats on it is way newer than the hardware so i doubt theres new drivers on there????
jim, device id? tell me how and i'll tell you it?
cheers all
cheers all
right click my computer... properties
harware tab
device manager
find the unknown device and bring up the properties
one of the tabs there will give u details about it, once ow chich will be th device ID (long string of gobeldygook)
still probablky easier to look at what make the card is tho
harware tab
device manager
Download something like Everest? It's an auditing tool and helps save IT bods loads of time by telling them what hardware is inside the machine! (well - most hardware anyway).
System Information
Time of this report: 12/27/2005, 12:47:18
Machine name: MATTLAPTOP
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: HIGRADED
System Model: Uknown
BIOS: Version 1.00
Processor: Intel Pentium III, ~1.0GHz
Memory: 112MB RAM
Page File: 107MB used, 160MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: SiS 300/305/630/540/730
Manufacturer: SiS
Chip type: SiS 630
DAC type: SiS
Device Key: Enum\PCI\VEN_1039&DEV_6300&SUBSYS_63001039&REV_31
Display Memory: 16.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: SiS300iv.dll
Driver Version: 5.13.0001.1100 (English)
DDI Version: 7
Driver Attributes: Final Retail
Driver Date/Size: 8/17/2001 14:56:04, 252032 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: sis300ip.sys
Mini VDD Date: 8/17/2001 12:50:46, 101760 bytes
Device Identifier: {D7B71ED9-2040-11CF-C577-014393C2C835}
Vendor ID: 0x1039
Device ID: 0x6300
SubSys ID: 0x63001039
Revision ID: 0x0031
Revision ID: 0x0031
Video Accel: ModeMPEG2_D ModeMPEG2_C ModeMPEG2_A ModeMPEG1_A
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SiS 7018 Wave
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1039&DEV_7018&SUBSYS_70181039&REV_02
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ac97sis.sys
Driver Version: 5.01.2501.0000 (English)
WHQL Logo'd: Yes
Date and Size: 8/17/2001 12:20:16, 297728 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xB5B
Min/Max Sample Rate: 48000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SiS 7018 Wave, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1039, 0x7001
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 01:07:00, 57600 bytes
| Driver: usbd.sys, 8/4/2004 01:07:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 01:07:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 01:07:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/4/2004 01:07:00, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: MS TCP Loopback interface - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 8.1 GB
Total Space: 9.6 GB
File System: NTFS
Model: FUJITSU MHM2100AT
Drive: D:
Model: QSI CD-ROM SCR-242
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 49536 bytes
System Devices
Name: O2Micro OZ6812 CardBus Controller
Device ID: PCI\VEN_1217&DEV_6872&SUBSYS_30001584&REV_05\3&61A AA01&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pcmcia.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 119936 bytes
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_00828415&REV_43\3&61A AA01&0&58
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: Texas Instruments PCI-1410 CardBus Controller
Device ID: PCI\VEN_104C&DEV_AC50&SUBSYS_00000000&REV_02\3&61A AA01&0&50
Name: SiS 7018 Audio Driver
Device ID: PCI\VEN_1039&DEV_7018&SUBSYS_70181039&REV_02\3&61A AA01&0&0C
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 01:07:00, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 01:07:00, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ac97sis.sys, 5.01.2501.0000 (English), 8/17/2001 12:20:16, 297728 bytes
Device ID: PCI\VEN_1039&DEV_7013&SUBSYS_70131039&REV_A0\3&61A AA01&0&0E
Driver: n/a
Name: SiS 7001 PCI to USB Open Host Controller
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_70011039&REV_07\3&61A AA01&0&0A
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 17024 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 57600 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_70001039&REV_07\3&61A AA01&0&0B
Name: SiS 300/305/630/540/730
Device ID: PCI\VEN_1039&DEV_6300&SUBSYS_63001039&REV_31\4&349 B7D1E&0&0010
Driver: C:\WINDOWS\system32\DRIVERS\sis300ip.sys, 5.13.0001.1100 (English), 8/17/2001 12:50:46, 101760 bytes
Driver: C:\WINDOWS\system32\sis300iv.dll, 5.13.0001.1100 (English), 8/17/2001 14:56:04, 252032 bytes
Name: SiS PCI IDE Controller
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_55131039&REV_D0\3&61A AA01&0&01
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:00, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/4/2004 01:07:00, 3328 bytes
Name: SiS 900 PCI Fast Ethernet Adapter
Device ID: PCI\VEN_1039&DEV_0900&SUBSYS_50021584&REV_82\3&61A AA01&0&09
Driver: C:\WINDOWS\system32\DRIVERS\sisnic.sys, 1.16.0000.0005 (English), 8/3/2004 22:31:36, 32768 bytes
Name: SiS630 Host CPU Bridge
Device ID: PCI\VEN_1039&DEV_0630&SUBSYS_00000000&REV_31\3&61A AA01&0&00
Driver: n/a
Name: SIS PCI to ISA bridge
Device ID: PCI\VEN_1039&DEV_0008&SUBSYS_00000000&REV_00\3&61A AA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 01:07:00, 35840 bytes
Name: SIS Processor to AGP Controller
Device ID: PCI\VEN_1039&DEV_0001&SUBSYS_00000000&REV_00\3&61A AA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\SISAGP.SYS, 5.12.0001.2010 (English), 8/3/2004 23:07:44, 41088 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 01:07:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 01:07:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 01:07:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 01:07:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 01:07:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:07:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 01:07:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 01:07:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 01:07:00 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 01:07:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:07:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:07:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:07:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:07:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:07:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:07:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:07:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:07:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:07:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:07:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
IndeoŽ video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
IndeoŽ video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
IndeoŽ audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
IndeoŽ video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
IndeoŽ video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
IndeoŽ video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IndeoŽ Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
IndeoŽ video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
SiS 7018 Wave,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
SiS 7018 Wave,0x00200000,2,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SiS 7018 Wave,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: SiS 7018 Wave,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
SiS 7018 Wave,0x00200000,21,3,,5.03.2600.2180
andy, will try that if the above doesnt help!
System Information
BIOS: Version 1.00
Memory: 112MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Manufacturer: SiS
Chip type: SiS 630
DAC type: SiS
Monitor Max Res:
DDI Version: 7
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x1039
Device ID: 0x6300
Revision ID: 0x0031
Revision ID: 0x0031
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 8.1 GB
Total Space: 9.6 GB
File System: NTFS
Drive: D:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
no its not stu, mini-pci cards show up as PCMCIA devices rather than PCI devices.
unfortunately matt it looks like a cheap shitty wireless card that doesnt report its status "properly" please open it up and read the part numbers off of it. you'll likely find 2 seperate compartments on the bottom, one for mini-pci and one for memory, the one you're after is the one that looks more complicated and is probbly taller
matt, as jim says, its just a cover @ the bottom, just be careful of the aerial/antennae.
Some Hi-Grade laptops are rebranded ASUS machines
What's the laptop model and I'll have a look (I used to work for them)
Some Hi-Grade laptop models are also badged as Advent and resold by PC World
i haven't really read what anyone else has put but i would just go on net, type in model and brand and fnd out what ya need thats what i need did for my laptop in end found out i didnt even need a card just a usb connector for it dunno if that will help your situation but you never know could have
It's made by Uniwill then.
Assuming it's a Pentium III, it should be one of these drivers
http://www.uniwill.com/UserDownload/N241/n241.htm
Disabled Account
14
25-10-2005 06:55 AM
Disabled Account
14-06-2005 06:17 PM
