Swirl pot Question >?
Old Dec 20, 2005 | 03:52 PM
rabmc's Avatar
rabmc
Default Swirl pot Question >?
What do these actually do guys for your cooling system ?
See the hose that connects into top that goes to header whats the function of this
Old Dec 20, 2005 | 03:57 PM
Jay,'s Avatar
Jay,
Sponsor
stops ur system foaming up the top pipe bleeds steam ect into ur header tank . think thats right lol
cheers jay
Old Dec 20, 2005 | 04:02 PM
rabmc's Avatar
rabmc
Mmm intresting
Old Dec 20, 2005 | 04:04 PM
bud-weis's Avatar
bud-weis
Football Cwazy
it's designed to remove the air from the water system, the air rises to the top of the swirl pot and returns to the header tank through that pipe, that's my understanding anyway
Old Dec 20, 2005 | 04:07 PM
mk2rstaff's Avatar
mk2rstaff
your right in a sense i think bud, i believe that air pockets build up in the system causing hot spots where there is no coolant just air so the air pockets are removed in the swirl pot therefore getting rid of the hotspots
Old Dec 20, 2005 | 04:22 PM
JamesH's Avatar
JamesH
If you remove the cap of the header tank, you can see all the water going straight back into the head tank from the swirl pot
Old Dec 20, 2005 | 04:25 PM
warleydaddy's Avatar
warleydaddy
They take £100 out your bank acount!!!
Pete..
Old Dec 20, 2005 | 04:26 PM
rabmc's Avatar
rabmc
I cant , there does not seem to be any water doing anything from that pipe ?
Basicaly started engine and done so about 1 hr ago and only water i seem to have returning is turbo ? it was just started though does that make a diffeence , alloy header tank so can only feel for water , but defo does not seem to be any from the swirl pot pipe
Old Dec 20, 2005 | 04:34 PM
mk2rstaff's Avatar
mk2rstaff
rev it a bit mate and put some pressure in the system
Old Dec 20, 2005 | 04:37 PM
rabmc's Avatar
rabmc
And if there is no water coming up this pipe what does that mean
So let me get this straight , i should have water coming up this pipe from swirl pot to header tank
Old Dec 20, 2005 | 04:41 PM
3drstretch's Avatar
3drstretch
There will not be as much water coming through this pipe as turbo return.But there will be some.Have you just filled water as the thermostat may have not open yet and therefore no water is there yet.
Old Dec 20, 2005 | 04:44 PM
rabmc's Avatar
rabmc
Ehh basically started it from cold and it was trunning 2 or 3 mins , then opened header tank and put my finger in there was water from turbo return but didn`t seem like anything from swirl
A slight heat in water from turbo return
Old Dec 20, 2005 | 04:47 PM
JamesH's Avatar
JamesH
Mine is alloy too mate, can still see it, very clearly
Old Dec 20, 2005 | 04:48 PM
3drstretch's Avatar
3drstretch
Thermostat aint opened yet then so probably no pressure to push water up pipe.Leave it tick over until hose on rad side of swirl pot is hot then look.
Old Dec 20, 2005 | 04:51 PM
rabmc's Avatar
rabmc
In the dark
Cheers stretch My aRSe was collapsing to say the least there , because i do seem to have a bit of pressure in the tank when been out driving Was thinking of removing water feed to turbo to help but who knows
Old Dec 20, 2005 | 05:06 PM
3drstretch's Avatar
3drstretch
Keep an eye on temperature to make sure you aint got a airlock and turn heaters on full on hot inside car.Make sure it on flat surface as well.Is it a 4x4 or 2wd as on 4x4 there is a bleed screw on thermostat housing.
Old Dec 20, 2005 | 05:13 PM
rabmc's Avatar
rabmc
Is a 2wd stretch , my car always has a fair amount of pressure in it , but always thought it ways to do mostly with turbo return , as my mates have no return and not as much pressure , if that makes sense
Old Dec 20, 2005 | 05:34 PM
rapidcossie's Avatar
rapidcossie
it should only be air in that pipe coming from the swirl....
Old Dec 20, 2005 | 05:36 PM
rabmc's Avatar
rabmc
Old Dec 20, 2005 | 05:43 PM
mk2rstaff's Avatar
mk2rstaff
you will get a mixture of both air and coolant mate its just not a straight return as from turbo just a release like an engine breather type effect, no straight current but if enough pressure applied it will come out
Old Dec 21, 2005 | 05:10 PM
rapidcossie
i have never seen water coming out of that pipe mate...
steady flow out of the return to the turbo but should only be air from the swirl pot...
the purpose of the swirl pot is to remove any air bubble from your coolant.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
