FAO turbo know it alls - UPDATED - its not magnetic
in the pic below... what is the threaded hole just below the wastegate arm for?
when i bought it it had a blue restrictor on it, why would this be?
so i had this made to do away with the blue restrictor
could anyone tell me the spec of this turbo from the part numbers stamped or embossed on it ?
ive tried searching in google but im not finding much of any use to me
thanks in advance
thanks in advance
Testing the future
as said, threaded hole is for lambda sensor to run closed loop fuelling.
the blue restrictor is to restrict the amount of air that the turbo can suck in, thereby reducing maximum power output to meet certain racing / rallying regulations.
Originally Posted by nightdavva
Originally Posted by DazC
It's a T034...
A T35 is a diesel turbo...
A T35 is std big turbo Escos........Exactly the same as on my Escos matey...
Same turbo was also used on Lancia Delta Intergrale Evo.....
Originally Posted by markk
show a pic of the turbine blades mate - there may be a few other trick bits in that unit
and one without
It's a T034...
Sorry Robbie... Daz is correct.
Originally Posted by Freddy_mercury_magic
Ben have you looked at the end of the shaft??
Could/might have a Maram 247 shaft....
Freddy_mercury_magic will have a look later today
I did but wasnt going to pass comment
care to enlighten me and the rest of us ?
Originally Posted by Damo V
Originally Posted by Neil S
I can't beleive that no-one has spotted the 'hairy arse' mod it's sporting!!!
Neil.
Neil.
and one without
in the pic of the turbine i was just looking at the spec of the shaft - non cutback - good for quick boost spooling , and seeing as weve got to mar-m shafts the whole thing needs to be non magnetic i.e the blades and the centre of the shaft - if a magnet will stick to it - it aint be made by mar-m
It's a T034...
and one without
here's the pic your after
its deffo all NON magnetic
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
Cameron
14
09-08-2015 06:28 AM
