S2 Mongoose exhaust HELP NEEDED! argh
my exhaust keeps breakin free and fallin off from the centre section jus under the hand brake area.
i have always used a stainless heavy duty jubilee type clip 2 hold this joint as need the ground clearance 4 my drive.
i have recently tried a brand new 1 but still no joy as goes 4 a std "U" bolt.
has any1 else had simalar probs ????
ur help will b much appreciated
(ps i have checked my engine mounts 2)
You need to get it on a ramp, make sure ALL sections are loosened off and make sure you get it right and that ALL U bolts/brackets etc are tight as fook and leavel each side
Mate
this will solve ya prob
Loosen everything off.. Do it on ramps or what ever.
Ram the middle section down the front section as hard as you fucking can.
I mean get some one on the back end and fuck hang off it till its on.
Now get 2 U clamps... BUT and this is the big bit.. if you go to halfords the biggest they do is about 3mm too small.. which is ideal as it makes it that bit even tighter.
1 You put quite close to the edge of the centre section and tighten it up evenly and make it fookin tight.
the second you put about an inch or so away and again tighten evenly but fookin tight..
Now adjust the rest and tighten as normal.
I 100% quarentee you that will not drop. I have done 20.000 miles of absolute hammer and since I did that it hasn't budged at all.
PICS TO FOLLOW
Shings
(yes I am going out in the cold now to photo it)
PICS TO FOLLOW
Shings
Buy a couple too.. I cannot stress enough if you dont snap a U clamp getting the correct tightness trying to do this then you are not tightening it enough.
Shings
Shings
Shings
Shings
good advice guys
k cheers 4 ur help guys.
2nite i have jus put 2 self tappers in it and if that dont work i think im gunna get the cnetre section (only) welded
but i hope this is gunna work
blakey100
04-08-2015 08:17 PM
jdsjojo
01-08-2015 08:56 PM
