where can i get hold of ....
Originally Posted by Tony Turbo
They are only Ł100ish
Just get hold of a seconnd hand one and have it blasted and powder coated, probably cost about Ł25, and it will be genuine so you know it will fit with no leaks etc........
Most pattern panel places do them
Hows your engine going Ian?, got any more power out of her yet?. I upped my boost to 1 bar a couple of weeks ago and managed 241 lb/ft of torque
Cheers,
Stu
Cheers,
Stu
its holding 16 psi 252 lb/ft but seems to get through a lot of oil since the rebuild not burning it small leak underneath but nothing excesive whats yours running now ?????
I didnt realise youve had to rebuild her mate?, what happened?, did Ferriday rebuild it or someone else?. Have you made any spec changes?
Mines currently setup to peak at 1 bar and then hold about 11-12 psi as Im still a bit nervous about my pistons. That gave 181 BHP and 241 lb/ft but ever since I had it setup its been running badly with spark blowing out on peak boost and popping and banging on overrun. Am now purchasing a wideband lambda meter kit than Im going to build and install so I can set her up myself from now on! - got a -31 to put on so that may well be the next move.
252lb is top work mate ! - ru breaking many boxes yet?!!
only 1 box what happend was the oil pump siezed and rounded the crank off and mike at ferriday rebuilt no real changes just some 17" vodoos iam having a break from spending to gather more funds fo a managemet conversion
mike elsome
14-09-2015 04:08 PM
