FAO Ford Peeps
08-12-2005, 12:57 PM
FAO Ford Peeps
I've been told that there is a fuel pump wiring repair kit available from Ford, containing the elusive clip with a length of wire attached.
I went to my dealer yesterday, and all we can find is 6129669 (83 BG 14A069 AB). They don't carry them, and the description was typically vague
Is this the correct part, before I order them?
If not, does anyone know the correct number?
Cheers!
Neil.
08-12-2005, 12:58 PM
What pump are you fitting Neil?
08-12-2005, 01:00 PM
Standard
I'm just re-wiring it.
Neil.
08-12-2005, 01:01 PM
941 jobbie? Cool, doing exactly the same but on my RST. I'll be interested in this as well then
08-12-2005, 01:04 PM
I thought the RST had the same pump as the Cosworth anyway?
Neil.
08-12-2005, 05:13 PM
Slight difference apparently.
08-12-2005, 07:41 PM
Boing!
Neil.
08-12-2005, 08:14 PM
yep correct finis you get about 2 inchs of wire with the connectors if still avab.
08-12-2005, 08:46 PM
Quote:
when I got mine there was about 10/12 inches of wire with them
steve
09-12-2005, 07:15 AM
Cheers DOO
I'm trying to source connectors only, but if I fail, at least I can get them from ford
Neil.
09-12-2005, 07:35 AM
09-12-2005, 07:37 AM
Just checked fords stock loads avab
09-12-2005, 08:02 AM
Plenty for everyone Dan!
Neil.
09-12-2005, 08:09 AM
DOO, while we're on, what exactly do you get with 1524780 - Alternator Fuse Link?
Neil.
09-12-2005, 08:46 AM
Quote:
Neil.
I think you just get a fuse not got any to look at but your not going to get a lot for Ł1.58
13-12-2005, 07:39 AM
*Update*
Neil/Doo i picked up part no. 6129669 yesturday, its only one connector & about 12 inches of wire! So you will need to order two Neil!!
Dan
13-12-2005, 08:09 AM
Thanks for the info Dan!
I'm off to ford at lunchtime so I'll order a pair
Neil.
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
Billy_RS
15
05-09-2015 12:04 PM
borboyous
22-08-2015 11:17 AM
