Carb Freeze - how to rid it?
Redumbdancy
Its the first winter i've been driving my mk3.5 Fiesta with a 1.1 HCS Carb'd engine and I seem to be suffering from carb freeze. Only mods are a bolt on k&N filter (and ive stupidly chucked the standard filter away )
Has anyone had the same problem? Any ideas how to solve it?
Monte 087
I used to have the same problem with a golf driver i had a few years back that i fitted a weber carb and k&n filter too, the only way to solve it really is to fit a hot air feed from the exhaust manifold or source a standard airbox and filter for the winter months.
PassionFords Creator
Originally Posted by cossiecrew
put a towel over it at night
Redumbdancy
Its strange though, the K&N seemed very hot, along with the inlet manifold - is it still possible that the inlet tract could freeze when everything else appaears to be warm?
Cheers for the advice so far
my xr2 tt does this on motorway runs,
the best way i found to clear it was to put my foot down for 15-20 seconds to build the charge temps up.
then it runs fine for a while.
i got the same problem on my 1.6s mother ran over the old filter , i got the water blocked of going through the manifold aswell, so it runs very cold, think hot air feed is the best idea mate. i'll have to get mine sorted out since it runs shit for the frist 10mins
Redumbdancy
Originally Posted by seventynine
i hardley recomend it, but its done me for 3 weeks untill i have the time to sort something proper out
Still can't believe i chucked the standard filter away Since the car was apparently running fine (or so i thought).
Redumbdancy
Originally Posted by motherhupit
just use some radiator, pipe and run it from the manifold (should fit over the neck) and run the other end to the K&N.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Mark_
40
02-10-2015 04:40 PM
