mondeo problem
Old Dec 1, 2005 | 02:02 PM
gus's Avatar
gus
Default mondeo problem
i have a mk 1 1800cc petrol mondeo
it drives absolutly fine
except every now and again and will keep stalling, does it when cold, when hot, its just completly random
then it will just clear itself and run perfect again
is there anything i should be checking, i have been over the car and its all as should be nothing lose or wires broke/disconected
not alot to go on i know but its me misses car and she is out at night in it, which i dont like
thanks
gus
Old Dec 1, 2005 | 05:58 PM
gus's Avatar
gus
anyone?
Old Dec 1, 2005 | 06:26 PM
dave green's Avatar
dave green
HOW OLD IS IT.
Old Dec 1, 2005 | 06:47 PM
FastFordChris's Avatar
FastFordChris
herd something simular happening on the 1.6 zetec the idle valve get stuck, its ment to be a really common problem.
someone posted up on here a few days ago with the same sort of problem theres was a link on how to fix it to.
Old Dec 1, 2005 | 08:31 PM
gus's Avatar
gus
its n'reg 1996
any ideas on how much a new iscv is for a zetec then?
anyone else had this
Old Dec 1, 2005 | 08:35 PM
jon@work's Avatar
jon@work
My mates car does this every 2 or 3 days. It's a 2.0 on a L plate. Just dips the clutch after a couple of seconds and it restarts.
Old Dec 1, 2005 | 09:05 PM
andymaac's Avatar
andymaac
check the wiring under the coil is not chaffing
Old Dec 1, 2005 | 09:49 PM
The Youth.'s Avatar
The Youth.
also check/ clean the maf sensor, which is the alloy cylinder with the black plastic top in the inlet pipework,remove it then CAREFULLY clean the wire element with a cotton bud soaked in a carb cleaner
regards,
steve
Old Dec 2, 2005 | 03:04 AM
gus's Avatar
gus
thanks chaps
will check all the above in the morning
Old Dec 2, 2005 | 08:09 AM
Farmer Giles's Avatar
Farmer Giles
I had a similar problem on my '97 1.8 Mondeo. Taking the ISCV out and giving it a good clean up with carb cleaner helped for a few weeks then it started happening again. I sold the car before I replaced though.
You might want to check the plug gaps, if they are too big then it can cause the revs to drop too far when returning to idle before it picks up again. Also if it's on it's original leads chances are they are shagged by now.
HTH
Martyn
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Brickhouse
Sep 20, 2015 11:47 AM
roomey
Sep 19, 2015 08:40 AM
Flateric_2002
Sep 15, 2015 08:41 AM
