secs monitors ???????????
Old Nov 29, 2005 | 08:33 AM
cossiecrew's Avatar
cossiecrew
Default secs monitors ???????????
are they any good then? anyone got info on them ? whats peoples veiws on them also whats a full list of things they read
Old Nov 29, 2005 | 08:40 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Blue screen Ł267 delivered, green screen Ł257 delivered.
http://www.secs.fsworld.co.uk/display.htm
Green in stock ready to go .
Old Nov 29, 2005 | 08:41 AM
cossiecrew's Avatar
cossiecrew
alot cheaper than i epected cheers mike ill take a read
Old Nov 29, 2005 | 08:43 AM
GARETH T's Avatar
GARETH T
i think every cossie should have one
Old Nov 29, 2005 | 10:35 AM
neilm's Avatar
neilm
When they first came out I thought they were the absolute bollocks... I loved it to bits...
But now......
After having a faulty one that went back to SECS and took months of e-mailing etc to come back and the fact that all it does is fuel my 'Cossie Paranoia' I would just say ignorance is bliss.....
You find yourself looking at the Water Temp one and going.... Oooh 88 Degrees.. thats a bit hot.... Hmmmmm dont like the look of that...
Touch your brakes and its down to 86, off the brakes and its back to 88
But if you look at the dash board temp gauge it aint moved a millimeter but the SECS has been from 82 - 88 and back again 4 times.
Same sort of thing happens when you turn the headlights on and off, the readings change.
They are too sensitive and on old Cossies with original looms.
Thats my personal opinion anyway.
Old Nov 29, 2005 | 10:40 AM
R4N SS's Avatar
R4N SS
they are a good bit of kit but as Neilm says if they go wrong they can be a nightmare to sort out, as lets face it Simon isnt the most reliable person is he
On the plus side Mike R and Spenner got mine sorted in a very timely fashion so I would not hesitate to use these guys instead for any repairs, etc.
With regards to Cossie Paranoia - isnt every gauge like that
Old Nov 29, 2005 | 10:47 AM
Mike Rainbird
Caraholic
Neil,
Firstly, Simon is not involved with the building or repair of these, so any repair work has a five day turnaround.
Secondly, the fluctuation of the water temps has nothing to do with the sensitivity of the SECS monitor, but is actually what is happening real time. My Pectel monitor is the same and the water temps fluctuate with speed. Also, I have a digital oil pressure gauge, and the oil pressure (naturally) fluctuates with revs - I suppose you'll be saying next that this is because the gauge is too sensitive .
I agree that it can give paranoid people too much information, but it certainly isn't a case of ignorance is bliss, as ignorance can cause a catastrophic failure . You soon learn to realise wjat is normal fluctuations and that allows you to identify what is abnormal .
pabloXR
Sep 21, 2015 12:42 PM
Roscopeco
Sep 14, 2015 05:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
K42L
Aug 28, 2015 01:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
