4x4 cossie clutch problem
Old Nov 26, 2005 | 06:43 PM
Fiecos Dan's Avatar
Fiecos Dan
Default 4x4 cossie clutch problem
since the PF daddy thrash my clutch hasn't been disengagin as it used to.
the clutch arm is now hittin the rear of the gear box casin (so can not release any more and still got some cover pressure on it, Where before now it would release the pressure and have some movement B4 it would hit the housin
i have today removed the cable, cut away part of the tunnel, so i can see the whole lot.
The release bearing is in the correct place.
The clutch works fine till it comes into full torque, and then it starts to slip abit,
Any idea's on reasons for this?
Old Nov 26, 2005 | 06:46 PM
SPADGE's Avatar
SPADGE
What pressure plate are you running?
Old Nov 26, 2005 | 06:48 PM
Fiecos Dan's Avatar
Fiecos Dan
Helix cover and paddle, it was made specialy for my torque,
Old Nov 26, 2005 | 06:51 PM
SPADGE's Avatar
SPADGE
Is the other end of the clutch fork attached solidly to the bell housing??
Old Nov 26, 2005 | 06:53 PM
Fiecos Dan's Avatar
Fiecos Dan
Yeah i checked that, its as it should be, i also got a spare box out, and measured them both, and the same.
Old Nov 26, 2005 | 07:03 PM
SPADGE's Avatar
SPADGE
Hmmm strange one that
Only thing i can think of thats left is the presure plate itself maybe something has come adrift and is making it not release properly?
Your not running the ratchet system on the cable are you?
Old Nov 26, 2005 | 07:04 PM
Fiecos Dan's Avatar
Fiecos Dan
yeah but its all new and workin fine,
as i've even took the cable off,
i was playin with the idea of notchin the gearbox housin, so the clutch arm releases more,
But that dont solve the problem.
Old Nov 26, 2005 | 07:58 PM
seveneigths's Avatar
seveneigths
Hello mate have checked the cable as they some get hot and snag or melt inside, is it free, just a thought as it happen to my mates cossie and he had the same problem by the sound of things.Try a new cable
Old Nov 26, 2005 | 08:04 PM
Fiecos Dan's Avatar
Fiecos Dan
Cheers,
but as i sed, i've removed the cable, its the gearbox casin stopin it now.
So its not,
Clutch cable, pedal or rachet.
nor has the release bearin broke up or moved (as i can see its not)
the only thing left IS
as Spadge sed the clutch cover/plate failure, or the clutch arm pivot failure. Niether or which can be sorted till box is dropped.
Old Nov 27, 2005 | 08:54 AM
Fiecos Dan's Avatar
Fiecos Dan
Any one have similar problems?
Old Nov 27, 2005 | 09:02 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You still having problems then Dan ?
Sorry no ideas to help you
Have you moved yet ?
Steve.
Old Nov 27, 2005 | 09:03 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
you sure you havent bent the arm?
Old Nov 27, 2005 | 09:07 AM
Disabled Account's Avatar
Disabled Account
Check that ALL the engine (block) to bell housing bolts are done up nice and tight. They can work loose and just 1mm or 2 mm gap/movement there can lead to the problem that you have.
Old Nov 27, 2005 | 09:23 AM
Fiecos Dan's Avatar
Fiecos Dan
will do in a minute,
but surely that will cause it to do the opposite.
Old Nov 27, 2005 | 09:26 AM
Porkie's Avatar
Porkie
Time for a hydraulic clutch I reckon mate
Old Nov 27, 2005 | 09:51 AM
Fiecos Dan's Avatar
Fiecos Dan
the clutch its self is the fault, not the cable system, well not this time any way
kosienutter
31
Aug 22, 2015 09:55 AM
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
druidgetafix
Aug 15, 2015 10:22 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
