HELP POWER DRAINING ???
Old Nov 26, 2005 | 11:21 AM
Sexy-RS's Avatar
Sexy-RS
Default HELP POWER DRAINING ???
If i leave my car in the garage for more than 2 days the battery dies!!!
Now i just went out to put it on charge and it would not even charge it was flashing from charging to charged/maintaing and making funny noises! Also as it was doing this i could see the light on my alarm dimming up and down!
So disconected the sounds, tv's ect from the battery thinking this may be causing it......Put it on charge and still the same! Disconnect everything of the battery and charge it and it is fine! Something is seriously draining my power
Any idea how to find out what
Old Nov 26, 2005 | 11:26 AM
SPADGE's Avatar
SPADGE
The battery may be shagged!
Old Nov 26, 2005 | 11:28 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Agree with Spadge - swap it with another and try that before you start panicking
mark's Avatar
mark
is there a light in the boot that comes on then you open it ?
thats what kills sierra battery's as sumhow thay stay on
Old Nov 26, 2005 | 11:29 AM
Redkop's Avatar
Redkop
Have a look here for all sorts of suggestions....
https://passionford.com/forum/viewtopic.php?t=151843
Old Nov 26, 2005 | 11:34 AM
Sexy-RS's Avatar
Sexy-RS
Battery Is a brand new one I got as i thought it was the battery to begin with
Not got a boot light!
Cheers Redkop will take a look
Old Nov 26, 2005 | 01:16 PM
Sexy-RS's Avatar
Sexy-RS
Any more suggestions
Old Nov 26, 2005 | 01:18 PM
Damo V's Avatar
Damo V
Read the topic red posted, willl tell you how to trace it
Old Nov 26, 2005 | 01:22 PM
Sexy-RS's Avatar
Sexy-RS
What you posted is very good Damo
But I don't have a ameter Let alone understand this bit....... remove -ve wires from battery bolt them together, then connect meter in series one end on batt other on wires
Old Nov 26, 2005 | 01:30 PM
Damo V's Avatar
Damo V
Can you borrow one??
Old Nov 26, 2005 | 01:31 PM
Sexy-RS's Avatar
Sexy-RS
Probably But I need it in simpletons terms what to do
Old Nov 26, 2005 | 01:35 PM
Ginge !'s Avatar
Ginge !
just finding my feet
fletch's brother is good at electrics aint he and not too far either i belive
Old Nov 26, 2005 | 01:37 PM
Sexy-RS's Avatar
Sexy-RS
Yeah maybe I will kidnap JB for the day if i can lol His always busy though these days!
Old Nov 26, 2005 | 01:40 PM
Ginge !'s Avatar
Ginge !
btw if its every 2 days that sounds a large drain, a interior light wouldnt do that i dont think as it was taking a week for mine
what alarm you got on it and try and diable that first ( though hide it in th garage incase a memeber sees this advice and tows the car away )
Old Nov 26, 2005 | 01:44 PM
Sexy-RS's Avatar
Sexy-RS
Its always locked in the garage lol Its a clifford G5 the 650 i think. I was going to try disconecting that but the wire from the Alarm don't go to the battery It seems to go behind the heater box then into the dash behind the clocks area
Old Nov 26, 2005 | 02:43 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
you are going to need a voltage test meter to find the fault.but they can be bought for 5 to 6 quid,try somewhere like woolworths for one.charge the battery and put the black wire from test meter on the negative of battery . red on the positive side. voltage reading should be about 12.7 v. if it stays the same after say 3 mins ,the battery is ok. connect the earth wires to the battery,then connect each wire one at a time to the posative side. checking voltage reading each time.when you connect the circuit that is draining the battery ,the reading on the voltmeter will slowly start to drop. ie 12.6 12.5 12.4 ect. most of the ones ive tested turn out to be the alternator. hope that helps
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
