cossie headgasket FAILED -UPDATED AGAIN ! :(
Old 23-11-2005, 10:22 AM
Dave Henshall
Dave Henshall's Avatar
Default cossie headgasket FAILED -UPDATED AGAIN ! :(
righty,
what are the options for my current setup, (ie std CR, 29psi peak and 25 held)
there are in my eyes the:
GrpA YB0611 -about £60 - may take it but not for long
std late escos YB1261 -about £35 - is this now as good as the grp A item?
Cometic MLS -about £150 - currently fitted but failed
Felpro - £dont know - heard that it is similar to cometic but less fussy about finish of head/block interface.
WRC 4 layer -about £400 - the dogs but too expensive
any other info apprecaited please.
Old 23-11-2005, 10:25 AM
Franco
Franco's Avatar
Mines got a Grp A fitted by Harvey, he reckons its fine for a stg 3!!
Also mine hits 1.9 tails off to 1.7 bar on greens, the only difference is i run a bosch pump.
Best to speak to Stu, see what he reckons (as its his set up!)
Old 23-11-2005, 10:47 AM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Cometic or Mountune 4 layer for me Dave.
Old 23-11-2005, 10:48 AM
If the cometic has failed then i would strongly suspect that either:
It wasnt torqued correctly
The block wasnt flat
The head wasnt flat
Old 23-11-2005, 11:50 AM
SapphyMike
SapphyMike's Avatar
I agree with Chip - you'd also have the same problem with a £400 Mountune gasket!
a fibrous gasket can go over most smaller imperfections in the block and head faces, but a steel one will not for obvious reasons.
Block face and head face MUST be 100% flat to use a steel gasket.
Old 23-11-2005, 11:57 AM
big_wig_074
big_wig_074's Avatar
Default Re: cossie headgasket options
cheaper than a new engine fella!
Old 23-11-2005, 11:58 AM
Porkie
Porkie's Avatar
I found that out the HARD way.... after buying 4 genuine WRC gaskets and doing less than 100miles in total !!! ooouchh wallet chaffer!
Old 23-11-2005, 12:28 PM
SapphyMike
SapphyMike's Avatar
ock! £1600ish down the swany! should've just given it to me
Old 23-11-2005, 12:42 PM
Dave Henshall
head was defo 100% as it has been skimmed, new ford head bolts were used and torqued down evenly in 3 stages. the block was check for flattnes and was also ok.
what about this though...
as i was rebuilding the head i pourded an amount of new oil over the cam followers and cam journals as i built it all up, obviously some of this will have run though the oil galleries and onto the head gasket as the head was being lowered into place, if oil had gotten on the top of the block and between the gasket and head, would this have prevented it from making a good seal on the faces, ie, does they not only have to be true and flat, but impecibly clean..?
Old 23-11-2005, 12:44 PM
Dave Henshall
stu, IYO, what should the boost be backed off to if i were to go for a grp A one..?
Administrator
Theres your failure.
The gaskets have a rubber type facing on them that seals to teh head surface under pressure. oil cannot be compressed very well so has compromised the seal.
Old 23-11-2005, 12:58 PM
Also, the oil will make its way out over time, guess what happens then?
Your head hasnt got enough clamping pressure now, so basically from my list you were on the option "not torqued correctly"
And if you fit another one now, after the gasket has gone you will be under "head not flat" probably!
Old 23-11-2005, 01:13 PM
Dave Henshall
that would explain the amount of oil that gets sprayed everywhere from the inlet frint side of the gasket.
I see said the blind man
cheers guys, much apreciated,
so what do i do now, just g for a grp A as at least that will allow for a lil bit of imperfection and make sure its super clean,
how does the late type esocs one fair in comparison to the grpA one?
Old 23-11-2005, 01:16 PM
Your sig is a bit unfair.
It should say
Cometic headgasket (Idiot proof, but installed by an upgraded version of idiot )
Personally, i would get the block checked for flatness, get the head skimmed the tiniest amount possible to be flat, and then go for a properly installed cometic (and get Stu to det check it as it will now be slightly higher CR)
Old 23-11-2005, 01:19 PM
Disabled Account
Disabled Account's Avatar
.........how does the late type esocs one fair in comparison to the grpA one?
It fares VERY well - Karl has even posted on here that it's a better design and superior constructed item
Not so long ago PJ Motorsport were selling them on "special offer" for £ 4.98 each
Old 23-11-2005, 01:26 PM
Dave Henshall
Old 23-11-2005, 01:42 PM
Dave Henshall
PJ's haven't got any std ones in
so i've just orded a set of headbolts and grp A gasket from woodford, £91.26 inc vat delivered.
another nice job for weekend
i'll post the pics of the old gasket etc up, at least if other people learn from my stupidity thats something
Old 23-11-2005, 02:30 PM
Dave Henshall
stu,
as my head can not take another skim, the CR may well go up due to teh slightly thinner grp A gasket as opposed to the thicker cometic one, will my chip still be ok, or should i drop the boost down a bit. bear in mind nothing else has changed since you set it up
Old 23-11-2005, 02:34 PM
Franco
Franco's Avatar
Doesn't the closed loop system control the boost though?!???!?!?!?
Old 23-11-2005, 02:39 PM
No, thats for off boost fuelling
Old 23-11-2005, 02:40 PM
stu,
as my head can not take another skim, the CR may well go up due to the slightly thinner grp A gasket as opposed to the thicker cometic one, will my chip still be ok, or should i drop the boost down a bit. bear in mind nothing else has changed since you set it up
It will need checking really.
Old 23-11-2005, 02:41 PM
SapphyMike
SapphyMike's Avatar
No, it controlls the fueling for non full throttle etc.
It has about as much do with controlling boost, as i have to do with selling cheese.
Cue Stu to shoot me down
Old 23-11-2005, 02:42 PM
Stu wont shoot you down, but can i give you a for being too slow
Old 23-11-2005, 04:24 PM
SapphyMike
SapphyMike's Avatar
LOL Chip - ah well, i was on the phone, so typing takes a back seat LOL
Old 27-11-2005, 03:02 PM
Dave Henshall
right, update:
whiped the head off, not really anythwhere noticeable where it had been passing water into no 2 and oil into no 4 though...
1,2
3,4
head
cometic top
cometic bottom
grp A
grp A fitted with 2 old studs as guides
new bolts, all torqued up , everything fitted back, re timed her, fired her up and no smoke, no missing no steam
wicked, just have to asee how ling it lasts now...
Old 27-11-2005, 03:13 PM
Ginge !
just finding my feet
Ginge !'s Avatar
Old 27-11-2005, 03:15 PM
JamesH
JamesH's Avatar
Old 27-11-2005, 03:16 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
The head wasnt flat
edited cause i did'nt read the whole thread
Old 27-11-2005, 03:23 PM
Dave Henshall
ive just noticed this that is didnt before,,,
could this slight scratch on the head have caused the water ingress?
Old 27-11-2005, 03:32 PM
I my opinion no Dave...if it went all the way then yes Dave.
Also IMO a metal gasket MUST be used in conjunction with long studs to get ultimate reliability.....They were designed for WRC cars which used 10 long studs which had increased clamping.
Old 27-11-2005, 03:34 PM
DazC
DazC's Avatar
The closed loop lambda/fueing control does the fueling. The closed loop boost control does the boost! P8 has closed fuel and boost control. I assume that Stu's chips retain the features.
Old 27-11-2005, 03:47 PM
Damo V
Damo V's Avatar
No2 is very clean though ay... presumably you cleaned the bolt holes out thoroughly?
can also see slight valve piston contact too
Old 27-11-2005, 04:18 PM
Damo good point you been over revving it Dave?
Old 27-11-2005, 05:14 PM
MalteseFalcon
MalteseFalcon's Avatar
In Malta we used group A , WRC 4 layer and others but nothing is quite good as The Italian Custom Made head gasket. The Zoqdi team( which was featured in Performance Ford magazine) races a 800bhp+NOS EscortMk1 Cossie drag car with these gaskits and no problems.
Old 27-11-2005, 05:55 PM
Fiecos Dan
Fiecos Dan's Avatar
my cometic seems fine, and done 4k miles of abuse.
hope it last's Dave.
Old 28-11-2005, 07:26 AM
Dave Henshall
yep, ran a tap down all teh bolt holes and blew the oil/water out with compressed air, no 2 was full to the top with coolant when i lifted the head off, the valve contact was like that before i did it last time, there is no evidenve of contact on teh valves so i assume its from when someone has timed it up badly in the past , i dont like revving it tbh, the best bit of the engine IMO is the mid range haul, the top end seems flat and pointless
Old 01-12-2005, 07:48 AM
Dave Henshall
driving in today, first time since it got it back together that its actually been on boost due to all the snow and all, but it fired up on 3, didnt clear for ages, then as soon as a little boost ca,e on a psshhhtt pop and loads of black/blue&white smoke out the back, give a little boost again and pop ding, loads of steam from under the bonnet, no more boost available and no water in teh header tank the head must go like a fookn pigs tail once it warms up the head must have gone porous or teh block has a hidden crack in it, fookn p1ssed off to say teh least,,, another £100 quid and a days work down the drain, after the £500 to have the head done and all teh gaskets last time.
fookin coosies
Old 01-12-2005, 08:33 AM
Administrator
Old 01-12-2005, 08:41 AM
wounder
Old 01-12-2005, 09:56 AM
Dave Henshall
what do we reckon, decent second hand head, and have the block skimmed,, can this be done in situ, or it it engine out job?
could the centre of the old cometic be used as a decompression plate if it were sealed to the block afterwards?
Quick Reply: cossie headgasket FAILED -UPDATED AGAIN ! :(
