XR4x4---- are the 2.8 and 2.9 flywheels interchangable?
I've just bought a 2.9 XR4x4 and a 3.9 V8 engine on Ebay and plan to do a 4 wheel drive V8 conversion using the MT75 gearbox, an adaptor plate and one off flywheel to use the Ford starter motor. I have access to a 2.8 flywheel to measure up but need to know if it is compatible with the MT75 box and starter motor? I know 100% that a cossie 4x4 cluch fits the 2.9 flywheel, will it fit the 2.8?
If not does anyone have a 2.9 flywheel nice and cheap?
Thanks for any help, I will post pics when conversion is under way
Mark
Mark
Team HOTHOT!
the flywheels are interchangeable on 2.8 and 2.9 yes - as its the same block.
however, the clutches arn't the same due to different gearboxes - type9 on the 2.8 and mt75 on the 2.9
Going to do somethink similar with a 3.5 turbo onto a 2wd gearbox, altho have been told leyland van gearbox is best as strong and reallly short will get some pics. Anyway i know you need a adapter plate for the 2wd boxes!
Team HOTHOT!
you van get bell housing off the shelf to mate a T5 to an RV8
Originally Posted by Graceland
edit to say, the clutch covers arn't the same, the spinner plates are tho
I allready have a rear wheel drive V8 Sierra using a T5 and adaptor bell housing and it for sale on Ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4587653264
A V8 4x4 has got to be the ultimate all round Sierra
Mark
the clutch covers aren't the same but they are interchangeable as its to do with the peddle travel i believe, u want the 2.8 flywheel as its lighter
Anyone running a 2.8 flywheel on a 2.9 XR4x4 on here?
cheers
Mark
