turbo seals :) headgasket :(
1 Post
does the cooling water just run though a jacketed area of teh body of teh turbo , or does it acually come into contact with the shaft..?
only reason i ask is cos since my turbo oil selas have gone it seem to be using a quite alot of water also, ..?
1 Post
that would maybe tie up with the slight miss on no 2 when it first starts then,
fook mei - its only just had a head rebuild inc skim and new cometic gasket 3K ago
the turbo oil seals are defo gone though, may have to live with teh head leaking a littl ewater, it doesnt over heat, and there is no oil/water mixing... yet
the turbo oil seals are defo gone though, may have to live with the head leaking a littl ewater, it doesnt over heat, and there is no oil/water mixing... yet
1 Post
could this be due to the skim in the first place. the machine shop did say thjey had to re seat the valve seats back in a bit due to it be being on its last legs (ie no more skimm sleft in it for a turbo spec)
here it is before/after teh skim
1 Post
i think he siad that they had to re cut the seat not due to the smmount they took off but due to the fact that the valves would touch the piston tops otherwise, the head must have been skimmed umpteen times in the past i reckon.
1 Post
bad news guys,
since doing the turbo, I was rather hoping for the seals to be buggered or have a crask in it - neither, but now its got new seals and bearings, it still smokes and is getting worse
damo, on your cometic what had failed, cos initially, mine was using just a smidge of water, now its a header tank every other day, and tehrer is quite a lot of blue smoke when its hot and it misses on no 2 every time u start it cos of water contamination. could it be just the gasket, or are we looking at at another head, what HG are u runnig now ?
1 Post
could it be the head dya reckon duw to these holes being made bigger due to the skim?
the head before the skim (cleaned off)
are these water jacket ports already too elongated?
and after, again are these now too far opened up...?
anyone else got come skimmed head pics
Ive been offline for few days...
I ONLY wanted a WRC HG on my new rebuild I'm afraid... for close up pics of my head, after meltdown, see my resto thread mate... BUT I wasnt loosing ANY water... I was simply pressurising the coolant system, mainly on boost...
Nowhere near as extreme as yours Im afraid
JK12
33
26-04-2021 12:09 PM
