efi fitting crank sensor pully from sierra cvh???
07-07-2004, 09:52 PM
500bhp Cosworth in making
did u have to take bottom end out to get the pully on if so might aswell just swap the engine to frst one!!!!
07-07-2004, 10:00 PM
wouldnt have thought so as you can fit a pulley with the engine in situ
07-07-2004, 10:03 PM
but this is a lot thicker pullt ryan im sure adam had probs
07-07-2004, 10:06 PM
for mine it was case of dropping the engine down and fitting if from the wheel arch!!! tricky but possible!!
07-07-2004, 10:07 PM
Engine Machinist
if its too thick to take off, just drop the engine down by undoing the mount and letting it down on a jack. you should have enough clearance then...
07-07-2004, 10:08 PM
07-07-2004, 10:10 PM
the pully has to be machined down or it hits on the inner wing!!!
no pics of it tho!! sure a few ie gadget ,jano will know more!!!
07-07-2004, 10:11 PM
Engine Machinist
roosie, you actually from bury, or just nearby? just curious cos i work there...
07-07-2004, 10:12 PM
well used live near bury and work there was always in bury every day and night in theford now what u drive?
07-07-2004, 10:17 PM
Engine Machinist
nothing at the moment
escort's broken and golf's got no tax.
you may have seen the escort (xr3i), mercury grey with white mondeo 12 spokes. i'm working at vauxhall at the moment. just trying to think if i've seen your car before....
07-07-2004, 10:20 PM
u wont have seen this car u might have sen my magenta cossie around i know your car do u come from newamrjet or didi the wheels come fromt that way
07-07-2004, 10:28 PM
Engine Machinist
i live near newmarket, got any pics of your cos? might recognise that. oh and whats your msn addy?
08-07-2004, 03:09 AM
08-07-2004, 04:36 PM
08-07-2004, 06:34 PM
Ex Ford Man
11-06-2008, 07:16 PM
Spanner monkey
As said, get the pulley machined down, undo the engine mount and then you'll have enough to get the pully on!
Don't forget you'll need a spacer though as the bolt will go tight before the pulley is clamped as the pulley is thinner than the standard one!!
Hope that helps??
12-06-2008, 05:48 AM
4 YEARS TOO LATE!!!!!!!!!!!!!
I don't think he's still waiting!!!!!!!!!!!
12-06-2008, 05:23 PM
Spanner monkey
manuel boeckx
13
03-10-2015 02:29 PM
Roosie
15-08-2015 08:09 PM
rdvil
Other Marques
15-08-2015 12:11 PM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
