Diff Picture request
Old Nov 1, 2005 | 01:33 PM
cossy abuser's Avatar
cossy abuser
Default Diff Picture request
Has anyone got a picture of a Cossy diff with the rear plate removed?
Or a picture of the diff unit out of the casing?
Thanks
Old Nov 1, 2005 | 01:55 PM
Ian3dr's Avatar
Ian3dr
Only one I got mate.....
Old Nov 1, 2005 | 06:17 PM
cossy abuser
fook me thats 4 diffs I have now without slippers in them, cheating bastards
Old Nov 1, 2005 | 06:19 PM
tracktoy's Avatar
tracktoy
how do you know it has no slipper in it?
Old Nov 1, 2005 | 06:37 PM
Spiky's Avatar
Spiky
thats quaife yeah???
so a std 2wd diff looks different to that
Old Nov 1, 2005 | 06:38 PM
tracktoy's Avatar
tracktoy
my thoughts too
Old Nov 1, 2005 | 07:01 PM
cossy abuser
my diffs have the planet gears showing, I thought if it was a LSD the planet gears were replaced with plates contained in a housing like in the picture, correct me if I am wrong tho
Old Nov 1, 2005 | 07:03 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
the easiest way to tell if its a slipper is to hold one of the shaft joints and turn the prop joint. if both sides try to turn the same way then its a slipper
if its a 2wd one, it should have 3.64 stamped in it, that ratio was cossie only i think?
tracktoy's Avatar
tracktoy
dont think so? i got spikys broken one in the garage, planet gears are lying in bits in the btm
Old Nov 1, 2005 | 07:04 PM
Spiky's Avatar
Spiky
we took the rear off my old lsd 2wd diff, and it didn't look like the above,
a quaife is sealed, std they not
someone will have a pic i'm sure
Turbo Zetec
Engine Machinist
you will only see the planet (which usually smash) and sun gears
the LSD part is enclosed in the crownwheel end somewhere.
if the planet gears are broken, both sides will not turn...
planets are only a tenner each from ford!
Old Nov 1, 2005 | 07:09 PM
cossy abuser
I know how to check, and these seem to turn both outputs the same way, but the last one I fitted just spins inside wheel when power is added. Thats why I was after a picture out of the casing aswell PLEASE
Old Nov 1, 2005 | 07:11 PM
Turbo Zetec
Engine Machinist
if you can wait a few hours, i'll get one up later on...
Old Nov 1, 2005 | 07:59 PM
cossy abuser
diamond geezer
Old Nov 1, 2005 | 08:23 PM
dojj's Avatar
dojj
Resident Wrestling Legend
pop over to interford or the fsoc
marty has got a whole strip down and rebuld thing showing whats what
Old Nov 1, 2005 | 10:43 PM
Turbo Zetec
Engine Machinist
sorry for the crappy picture, it was dark.
this one has the suns and the planets missing.
Old Nov 2, 2005 | 05:36 AM
cossy abuser
ta
where is interford? would like to see their display
Old Nov 2, 2005 | 06:09 AM
martysport's Avatar
martysport
Here ya go
Inside a open type diff;
http://www.v6sierra.com/backup/dif/inside.htm
Lsd type;
http://www.v6sierra.com/backup/314lsd/314.htm
And some other diff stuff;
http://www.v6sierra.com/backup/diffs/diffs.htm
And a few from a Cossy Granny diff
Old Nov 2, 2005 | 06:33 AM
cossy abuser
So is the LSD inside the crown wheel then?
Thanks for the pics
Old Nov 2, 2005 | 06:50 AM
martysport's Avatar
martysport
Thanks for the pics
Sort of 'on the side ' of it
Its easy to tell if a diff is viscous LSD or not too
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
