2wd t34 boys ( quickie )
Just a quickie , basically wondering what actuator everyone is running , and boost mines is currently 22psi holding about 17-18 , and im going to invest in a new actuator and wondered if i should up the boost slightly and what actuator to run its got the ususal greens , 500 cooler set up
Would like it to hold 22 psi , and would it be easier to adjust through a bleed valve
Any help appreciated
Originally Posted by jacko
32psi on a dash 34 with grays and a 500 cooler had fuling checked and its fine
Right so a -31 should be okk then , cheers
oh and whats the most boost u can run on greens
I know mate i should , was struggling to shake a scooby the other day
Wasn`t standard though , but a bit more consistent boost and i would have been long gone
does go well my mate has a stage 3 but he drove mine and shat his pants your amle valve has a small white restrictor in the tiny pipe that goes to the air filter if you remove this it will up the boost
MMMm i have a k+n filter and the pipe that i assume used to go to airbox just vents to atmosphere is this still ok guys it basically comes off amal valve and points into the wing
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
