.63 exhaust housing
.63 should get your 0-100 times down,mine feels so much quicker after fitting a .63 after having a .48 I got mine off a guy on here for £70 delivered Just be careful that they are not too badly cracked under the penny washer otherwise it will make the turbo feel lazy.
Managed a 8.7 to 100mph with one on mine
Wyn its slightly bigger in diameter,when you look at the exhaust housing where the actuator goes you can get your hand in the gap between the actuator and the housing on a .48 you cant with a .63
Heres a pic of the new housing on mine and you can see the differance from the distance from the actuator rod to the housing.I could get my hand in that space with the .48 before,now i cant. Its only slightly bigger in circumerance in that area off the housing,the rest is all the same
