Cossie Engine Mounts
Old Oct 26, 2005 | 09:05 PM
Daveyraveygravy's Avatar
Daveyraveygravy
Default Cossie Engine Mounts
My engine mounts have gone a bit soft with age on my 4x4 Saff
I've been told that it's best to fit the Escort Cossie Engine mounts, as it would improve the handleing because it raises the engine slightly
What do you guys think?
Thanks in advance
Old Oct 26, 2005 | 09:10 PM
Billabong's Avatar
Billabong
Not sure about the height thing, but the Escort ones are 'beefier' as I understand it.
Or, you could go for these: uprated engine mounts
I have these fitted to mine.
HTH
Bill
Old Oct 26, 2005 | 09:12 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: Cossie Engine Mounts
Thanks in advance
i can supply you with new alloy/rubber mounts which are much better than sierra or escort one's at £130pr delivered
Old Oct 26, 2005 | 09:20 PM
Daveyraveygravy
Thanks foe the quick replies guys
£120!! Thats an excellent price Martin
I work for Fords and the standard ones were gonna cost me that much
So i might as well buy the uprated ones off you when i'm ready mate,
Are they hard to fit?
Thanks again
Old Oct 26, 2005 | 09:24 PM
Martin-Hadland
Thanks again
not too bad to fit, although you might need to remove the driveshaft from the front diff on the o/s to enable the engine to be jacked high enough to remove the mount
Billabong's Avatar
Billabong
Shouldn't be any harder than std ones to fit, but my engine was out at the time. Drivers side could be a bit hassly though I'd have thought....I'm sure someone who's actually done the job with their own fair hands will pop along and add some good advice... (EDIT: and lo and behold, Martin posts before me!)
Old Oct 26, 2005 | 09:27 PM
Neil S's Avatar
Neil S
I found the drivers side easiest - access on the passenger side is tricky because the Oil Filter elbow gets in the way. I dropped the crossmeber and supported the engine from above to do it
Neil.
Old Oct 26, 2005 | 09:42 PM
Daveyraveygravy
Thanks guys
I will be working from underneath as i have got access to a 2 pillar lift.
Could i just support the engine from underneath then remove the 4 crossmember bolts & the 2 nuts on the top of the old mounts, then lift the engine up with a gearbox jack, remove the old mounts then put the new ones in & lower the engine onto them?
Will this work? Sounds like it's gonna be alot harder than it looks
Old Oct 27, 2005 | 04:42 AM
Daveyraveygravy
Old Oct 27, 2005 | 06:59 AM
Eagle's Avatar
Eagle
Super Moderator
did mine on a 2 poster .. bit tricky but drop the subframe down a bit .. and you can just get em in ...
Old Oct 27, 2005 | 06:24 PM
Daveyraveygravy
Thanks Mate
Old Oct 27, 2005 | 06:26 PM
DaveEscos's Avatar
DaveEscos
Thanks again
fuck that!
just jack the engine up, and lofer the crossmember slightly!
SmudgerByName
52
Jul 28, 2016 06:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
