what turbo to go for........................
would stage 3 turbo be ok on my spec?
195 chip
GRS
16psi
zorst
K&N panel
pace rad
thats all ive done
if not, what else would i need to do for it to be beneficial?
195 chip
GRS
16psi
zorst
K&N panel
pace rad
thats all ive done
got a choice between new stage 2 or a 2nd hand stage 3 for the same price
which 1?!?!?
also are all stage 2 turbos the same? and same with stage 3?
cheers lads
which 1?!?!?
cheers lads
may mate has same spec and the stage 2 T3 works fine!
not sure on the ins and outs but im sure ive read on here before that most prefer the stage 2 to the stage 3!
anyone care to explain it?
The choice boils down to this: If you want it punchy with no more lag than now, then stage2. Putting a stage 3 on makes it laggier, but a lot revier and will produce more power.
Rick.
Rick.
Stage 2 is fine for that spec. I still use a stage 2 and have a pretty good spec. Buying new you are covered by manufacturer warantee. The only difference between the two is the addition of a .48 housing on the Stage 3
thanks again lads, the stage 2 one is not from a supplier, just from a random guy selling it as hes sold his car, and never fitted the blower. it is new tho
does it matter who did the turbo? i.e are stage 2 turbos different or a stage 2 a stage 2 doesn't matter what company it came from
Can you trust the seller 100%?
As far as I'm aware the stage 2 is as per stage 1 but with a 360 bearing. Can the seller give you the paperwork for this turbo?
i dont know him but he's a mate of someone off escortrsturbo.co.uk which iam also a member of.
gonna try find out where he purchased it from n check the serial numbers out
Now then Davie!!
What you doing over this side buddy ???
How we doing mate,
as said above really all depends on if you want response or big hp figures.
I had the same spec as you and ran a Stg 3, not much problems with lag but i ran a cam in the head aswell, dont know if this helped towards the lag or not ???
Regards - Adi
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
How we doing mate,
Regards - Adi
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
JK12
33
26-04-2021 12:09 PM
