cav
Old 22-10-2005 | 06:36 PM
ricky's Avatar
ricky
Default cav
can some one tell me that yellow symbol shape like an engine
on a vaxhaull cav dash what does it mean
its lites up then car cut out then start after a few minutes
any one
Old 22-10-2005 | 06:38 PM
kevmk2's Avatar
kevmk2
Thats the engine warning light,usually has to be turned off by vauxhall,maybe a sensor at fault
Old 22-10-2005 | 06:41 PM
ricky's Avatar
ricky
yea but its am8 cav just add an engine fitted
he drives it for about an hour then the light come on
then it cut outs never happned before until had engine fitted
what sensors you recond it could be
Old 22-10-2005 | 06:44 PM
kevmk2's Avatar
kevmk2
It could be a crank sensor,i used to work for vauxhall but in the parts department,so didnt get too involved in that side of things.
Old 22-10-2005 | 06:47 PM
ricky's Avatar
ricky
is the crank sensor ,would it come with
that engine he add fitted or would they add to remove is original
one and fit to this engine
Old 22-10-2005 | 06:52 PM
kevmk2's Avatar
kevmk2
If it was a second hand engine they would probably of used what come with it,if it was a recon engine then they would of used his sensors i would of thought
Old 22-10-2005 | 06:54 PM
ricky's Avatar
ricky
cool m8 nuff said
by the way wats your spect of that mk11
looks
Old 22-10-2005 | 06:57 PM
kevmk2's Avatar
kevmk2
Body:
Stock RS2000 Shell,Fibreglass bonnet and bootlid.
Doors drilled for lightness with starret Cutter.
Grp4 Style Large Gearbox Tunnel.
Single Wiper from Fiat Uno.
Colour Radiant Red
Engine:
Bottom end:
Cosworth YB.
Ford Motorsport 200 Block
Coopers Rings
Cosworth Forged Pistons 8:6:1 compression ratio
Knife Edged Crank
RS500 Rods
Oil spray jets
H.T Racing Big winged baffled Sump
Long Studded head bolts.
Bailey Oil Seperator.
Dynoed @ 405bhp and 450 Ft Lbs Torque (Field Motorsport Dyno)
Top End:
WRC Head Ported and Polished
Double Valve Springs BDG Spec
Lowered Platforms in head
BD14 Inlet Cam
BD8 Exhaust Cam
Phase sensor on rear of rocker cover for dizzyless ignition
Turbo:
T34 Hybrid With Restrictor pipe fitted but unrestricted (waisted inside)
Forge -34 Actuator .63 Exhaust Housing.
Injectors/Fueling:
8x Dark Blue injectors
WRC Inlet Manifold
O-Ringed to head
Mountune Fuel Regulator (5.0 Bar)
-6 Braided Fuel hoses throughout the car,run inside.
Bosch 044 Fuel pump
Holley 110 Gallon per hour lift pump
Alloy Swirl pot.
Cooling:
The Rad and intercooler are made for cosworths,my mate jason made them fit an escort.
Pace 50mm Rad.
Radtec RS500 intercooler.
2wd Cossie Fans.
Silicone Hoses throughout.
Bailey Swirl Pot.
Pace one off Header tank. (thanks dan)
Electrics:
P8 ECU with Anti lag and pectel piggy back board.
Zetec Coil pack.
Ford Motorsport Plug leads.
Motorsport wiring loom.
Twin Ignition modules.
Exhaust:
Mongoose 2wd Sierra downpipe cut and shut to fit.
Hayward and scott stainless centre section.
Mongoose 2wd Sierra Rear box modded to fit.
Transmission:
2WD Flywheel and AP 4 Paddle Clutch
T5 Borg Warner Gearbox
Pro 5.0 Mustang Shifter
One Piece Prop (bespoke)
Hydraulic clutch.
Axle:
Atlas Axle Shortened By H.T Racing
Quaife Grp1 Two Piece Halfshafts With ZF splines
Zf Motorsport LSD with twin clutch plates. 70% lock.
3:7:5 Diff Ratio
Suspension:
Front: Gartrac Bilstein 300/70 rated short legs with 2 1/4"350lbs springs.
Rose Jointed top mounts (eccentric).
Alloy Hubs.
Rose jointed adjustable Track control arms.
Rose jointed compression struts.
No anti roll bar.
2.0 Degrees Neg camber.
Rear:
Leda 24 point Adjustable 2 1/4 Coilovers with 14" 150lbs springs.
5 Linked with rose joints.
Brakes:
Bias Pedal Box made by H.T Racing
All Brake lines Braided and run inside the car.
Hydraulic Line Lock.
Front:
310mm two piece Vented Discs with AP Racing 4 Calipers.
Ferodo DS3000 Pads.
Rear:
XR3i Front discs and calipers mounted on axle.
Ferodo Standard Pads.
Alloy Fly off handbrake.
Wheels And Tyres:
Compomotive ML 7x15 Grp4 Style
195/45 Toyo Proxes TS1 Tyres.
Interior:
Sparco Evo Seats.
Willans 6 Point Harnesses (FIA SPEC)
Stack ST700SR Tacho/speedo with boost display and fuel pressure.
Racetech Oil pressure gauge
Racetech Water Temperature Capillary gauge.
Smiths Fuel gauge.
All mounted in carbon fibre.
12 point Safety Devices Roll Cage. Welded in.
Ralloy Alloy centre console with relays and switches.
Rs 4 Spoke Steering Wheel,on quick release hub.
Dash top flocked by Central Blast Cleaning.
Standard Rs2000 Door cards.
Alloy firewall.
Large diff tunnel.
No heater.
Underside of car painted body colour.
Here you go mate LOL
Old 22-10-2005 | 07:02 PM
ricky's Avatar
ricky
fuk me did you add reahurst all that thats very impressive
Old 22-10-2005 | 07:05 PM
rscozzysie's Avatar
rscozzysie
that's some spec mate
Old 22-10-2005 | 07:18 PM
kevmk2's Avatar
kevmk2
Cheers mate,i typed it all out in a word document ages ago so i didnt have to keep writing it out when people asked the spec,good old copy and paste LOL
1968unclefester
20-06-2010 02:12 PM
Martyn
56
26-02-2007 09:55 AM
Martyn
16-04-2006 06:00 PM
T28 RST
24
14-03-2005 01:15 PM
Quick Reply: cav
