help adding an amplifier
Old Oct 13, 2005 | 10:28 AM
hendy31's Avatar
hendy31
Default help adding an amplifier
i've got a mk 6 escort and i'm trying to place a sub and amp. i tried for hours trying to get the power lead from the battery compartment to the boot but i cant find an inlet to the inside of the car. any ideas
Old Oct 13, 2005 | 10:33 AM
red october's Avatar
red october
huge grommet where the main looms passes into the cabin from bonnet - poke through next to that! - i think its in a different place to mine compared to your car but there is always room for a carefully inserted extra length fnar fnar!
Old Oct 13, 2005 | 10:39 AM
hendy31's Avatar
hendy31
yeah i tried that but i can't seem to grab it from the other side. what if i drill a hole down the side of the battery, i think this goes into the cabin area, ialso tried putting it down through the front panel cause theres a great big cable that enters the cabin there aswell but i just can't get to the cable. what can i do?
Old Oct 13, 2005 | 10:51 AM
hendy31's Avatar
hendy31
any way what do you mean by main looms
Old Oct 13, 2005 | 11:03 AM
motherhupit's Avatar
motherhupit
make a new hole by the passanger foot well us a grommet and feed the wire down the plastic cover by the door that runs to the back seats, i wouldn't put the cable down by the main wiring loom u could pick up or cause interfierence.
Old Oct 13, 2005 | 03:01 PM
red october
use decent cable - will not get interference as there is no signal wires there!! - or drill a new hole but do not drill it vertically as you may well cause a leak even with a grommet
the main loom from engine bay to dash board will be in a big grommet with enough space round it for a new hole - push a bit of coathanger thru it & attach power cable to other end once thru then pull it back the other way so cable feeds into cabin!!
good luck
Old Oct 13, 2005 | 03:08 PM
motherhupit
whatever u do make sure u fuse it and don't run the speaker cables with the power cables or u will pick up interference
Old Oct 13, 2005 | 05:20 PM
Ritchie Newell's Avatar
Ritchie Newell
It's prety much the same with all car's, there is a rubber gromit in the engine bay about the size of an orange in the engine bay follow some of the other cables in the bay and they should lead you to it!
you think thats bad when me and a mate tried to fit his head unit in his probe we didn't realise the thing had a built in amp fitted in 1 of the back quarters we wer both sat there for ages.
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
pabloXR
Sep 21, 2015 12:42 PM
