on a RST, when you remove the oil cap
Old 10-10-2005, 01:54 PM
Westy
Westy's Avatar
Default on a RST, when you remove the oil cap
should it stall or still run...
This is with a Bailey breather kit, so not sure if it makes a difference
ta
Old 10-10-2005, 01:57 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Should stall
Old 10-10-2005, 02:04 PM
Westy
Westy's Avatar
cheers mate
any difference when hot or cold?
Old 10-10-2005, 02:09 PM
andre_k
andre_k's Avatar
mine dont stall
Charlie Chalk
Unknown.
Dont think so, why you asking?
Old 10-10-2005, 02:12 PM
Westy
Westy's Avatar
mine stalls and my mates RST doesnt, so was wondering why the difference
cheers mate
Old 10-10-2005, 02:15 PM
Charlie Chalk
Unknown.
You got a good engine if it does stall
Adam_BlackRS
Ex Ford Man
Adam_BlackRS's Avatar
If its plumbed to vent into the atmosphere, it won't stall !?
Old 10-10-2005, 02:18 PM
Charlie Chalk
Unknown.
I cant remember the reason...
Old 10-10-2005, 02:19 PM
Jim Galbally
Jim Galbally's Avatar
It depends how its plumbed in. (as adam says)
Old 10-10-2005, 02:27 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
If the breather system is connected in any way with the metering unit as they are as standard, the engine will stall unless its VERY badly setup.
Old 10-10-2005, 02:29 PM
starturbo
starturbo's Avatar
Ive had three rs turbs and theyve all stalled when you do that.They even stall when you pull the dipstick out?God knows why?????
Old 10-10-2005, 02:30 PM
starturbo
starturbo's Avatar
There you go the man himself.Didnt see what he wrote before writing that.
Old 10-10-2005, 02:42 PM
Adam_BlackRS
Ex Ford Man
So if its NOT plumbed into the metering unit and instead vented to the atmosphere, it won't stall ??
What if you don't have a metering unit ??
Old 10-10-2005, 02:46 PM
Stealth Bomber
Stealth Bomber's Avatar
That's silly.
Old 10-10-2005, 02:57 PM
DazC
DazC's Avatar
If you don't have a metering unit, it won't stall!
It's all related to the vacuum drawn by the engine and the fact that the breather is piped into the vacuum side of the metering unit. If you remove the breather from the meter unit, it won't stall as the vacuum is unaffected.
starturbo
starturbo's Avatar
That's silly.
Might be silly but its true.I didnt design the bloody thing.
Old 10-10-2005, 03:01 PM
Rick
Rick's Avatar
Stealth Bomber wrote:
That's silly.
It's because the crankcase is part of the breather and plumbed into the metering head.
Old 10-10-2005, 03:04 PM
Lets throw an interesting scenario into it then....
I had a car towed here from another tuners that wouldnt idle after having Ł350 of injection parts thrown at it unsucesfully... after much pissin around and head scratching I fitted a crankshaft rear oil seal. Problem solved
Be carefull out there chaps
Old 10-10-2005, 03:08 PM
keithG666
keithG666's Avatar
after much pissin around and head scratching I fitted a crankshaft rear seal oil. Problem solved
a wha?
Old 10-10-2005, 03:10 PM
starturbo
starturbo's Avatar
I had a car towed here from another tuners that wouldnt idle after having Ł350 of injection parts thrown at it unsucesfully... after much pissin around and head scratching I fitted a crankshaft rear seal oil. Problem solved
So thats a good way of knowing all your seals are ok then Stu?
Old 10-10-2005, 03:21 PM
Rick
Rick's Avatar
i wouldnt say, that - but if probably indicates that u HAVE a seal of somesort...
Stu, im guessing it was big power MFi and the petrol in the oil had eaten the seal
a wha?
Bloody keyboards
Not really pal, as it will pass a fair bit of oil before it will induce enough air to affect the metering unit calibration.
Old 10-10-2005, 03:54 PM
Steven_RW
Steven_RW's Avatar
Crank case/dip stick/breather/metering head are all connected on a standard car. Thus removing the oil filler/dipstick or any of the breather hoses will induce an unmetered air leak. If the cars not running SUPER rich then the chances are it will stall due to being to lean.
If you block the feed to the metering head this wont happen. However the breather system wont have the vacum its designed to have. Also if you remove the one way valves from the left hand nippled ontop of the inlet manifold the dipstick often blows out because the crank case receives boost pressure.
RW
Old 10-10-2005, 05:07 PM
Patto
Patto's Avatar
just last week my car decided it didnt wanna idle at all just cut out, was fine if you give it a little revs and driving was ok to ( felt a little slugish ) so after checking pipes and anything else i could think of i changed the R/C gasket finding the old one had a hole in it no massive but big enough to cause me agro! BLOODY RST's lol
CheeRS
Craig
NYRSOC
Old 10-10-2005, 06:59 PM
starturbo
starturbo's Avatar
R/C gasket
I am a bit knackered and have been scratching my head but I give up.What the fook is that.Gonna hate asking coz as soon as I press submit its gonna pop into my head.
Old 10-10-2005, 07:00 PM
starturbo
starturbo's Avatar
I knew it.Rocker cover.damn it.look at the time.its seconds before I realised.
Old 10-10-2005, 07:13 PM
James Raby
James Raby's Avatar
Anyone want to shed some light on why mine starts then stalls immediately? Then have to crank for about 40 seconds before it starts again??
Been driving me nuts, and I WILL keep this car in it's current form if someone CAN help me, please??
Old 10-10-2005, 07:20 PM
Stu.H
Stu.H's Avatar
moisture on the pistons
Old 10-10-2005, 07:21 PM
James Raby
James Raby's Avatar
And why would I have that
Only ever started being a bitch when I tested the battery, was actually starter motor
Was fine uptil that point
Old 10-10-2005, 07:24 PM
Stu.H
Stu.H's Avatar
dunno mate
all it is, i had EXACTLY same prob on my fezzy, if it started and i revved the TITS off it for about 30-40 secs or so it would be ok
if i just started it, let it cut out, it could take MINUTES of cranking to get it to work.
It happened one night while a mate of mine who is more mechanically minded than me (hi tony), and all he could put it down to was the above reply.
take my reply with a pinch of salt tho matey
Old 10-10-2005, 07:26 PM
James Raby
James Raby's Avatar
Well, If I give my car ANY throttle it won't start full stop after the stall incident
If I just crank it's ok and will start after about 30 seconds...
Old 10-10-2005, 08:05 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Mine will start, and then cut out, then it wont start, so i just get someone to hold the metering flap down a few mm and it'll fire up, run, but cut out if i give the throttle a jab, if i want i to rev from cold idle i need to bring the throttle on very slowly. . . i dont know if it will start without the metering flap being held down as i can be arsed cranking it to find out as it's just easier to hold the flap, i disco'd the cold start valve and it seemed to help a little at first, car doesnt get started often, so this prob the reason, but it done a 100 mile round trip, and iirc it struggled to start again the next day. but starts perfect if its been run, then left to cool down, just overnight it's a coont
p.s. mine cuts out when removing oil cap.
Old 10-10-2005, 08:31 PM
James Raby
James Raby's Avatar
We are as one, EXACTLY the same problem
Old 10-10-2005, 08:34 PM
vroooom ptssssh
It Wasnt Me!
HELP vroooom ptssssh and James Raby, in need
Ive got a feeling it may be the thermo time switch? havent got round to swapping mine yet.
Old 10-10-2005, 08:38 PM
James Raby
James Raby's Avatar
Don't say that cos made fak all difference on mine
Old 10-10-2005, 09:30 PM
Rick
Rick's Avatar
James, im pretty sure u have the same problem as Linsay did. When u crank the engine, the vacume pulses the metering flap which allows it to start. Problem is, as the engine wears (urs has done a fair bit hasnt it?) the rings don't seal very well at such low cranking speeds, and it doesn't depress the flap. If u continue to crank and crank, eventually u build up enough fuel to fire the engine - the increase in speed draws the flap open further and keeps her running.
What sort of CO u running? Turn the CO screw 1/8 turn clockwise and see if this helps.
Rick.
Old 10-10-2005, 09:33 PM
Adam Ash
Adam Ash's Avatar
VROOM and JAMES .....
check your fuel accumilators. little pots on the inner wing with a feed and return on top of it..
had the same problem on my xr2 turbo
Old 10-10-2005, 09:41 PM
©hatter Box
©hatter Box's Avatar
it will be the fuel press switch on side of the metering uniit i bet the wire is damaged!! saying that take the plug for the fuel ecu off and see if its starts better
Rick
Rick's Avatar
what - u mean u didnt fit one
Quick Reply: on a RST, when you remove the oil cap
