on a RST, when you remove the oil cap
#43
Originally Posted by Alex zvh cabrio
it will be the fuel press switch on side of the metering uniit i bet the wire is damaged!! saying that take the plug for the fuel ecu off and see if its starts better
Rick, recently tested at 2.5
#46
Originally Posted by Stu @ M Developments
Yo have i presume checked the heated seats fuse is ok havent you?
#48
It Wasnt Me!
ive not checked my heated seat fuse, but car was set up a year ago and hardly been used so assume it is ok, also another problem, it now boosts to 12 psi instead of standard set up and 7psi i got it set up for (turbosystems chip) also has a -31, is this ok, it wont be doing any harm at 12psi with a chip will it? (think the amal valve may of packed in, would this cause the raise in boost?) also when boost is brought in hard it hesistates and pops n bangs well it did but seemed fine the other day
#50
It Wasnt Me!
plugs and leads look shite, it DEFFO needs a new set of leads, i thought this might be the problem
also forgot i fitted a2nd hand tank (which didnt leak ) but it had surfice rust inside, i know i should of cleaned it out but heind sight is a great thing and i fitted it but the car runs perfect apart from this and has a new fuel filter, which i will replace once i fill the tank a couple of times.
#53
the reason for vent to amosphere is so all the shit does not go back to the metering head, and mine ticks over better , what i should have realy is a catch tank
andy
andy
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
