ISCV is it needed???
after having problems with the idle speed control valve on my sapphire cosworth i have taken it off several times and gave it a good clean out, the revs still seem to go up and down
i have now just unpluged it and the car seems to run and tick over much better. is it ok to do this or should it be plugged in ?? cheers
How about buying or getting hold of a Hitachi Valve and get it to fit since these a lot better than the Webber ones. not sure if it would be that simple but if possible u could fix it.
DEYTUKURJERBS
if it idles etc ok unplugged, leave it unplugged.
i had no ISCV on my cossie was it was replaced with an anti-lag valve.
only on the VERY coldest of mornings (i mean minus somthing) it would stall 1st time if wasnt careful, but 2nd time itd start and idle easy.
99% of the time itd start on the button and idle fine with no valve.
U can get the Hitachi Vales of late mk3 fiestas i know that for sure but most injection fords probally use them.
U can buy new Hitachi ones since thier a sealed unit.
yes you can get new ones at around 100 pound but they are tempremental as the one on there is only 6 months old or so. the revs only go up and down a bit but its enough to reallly bug me.
so when you put anti lag on you do away with the valve anyway then??
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
