After advice from Kieth Cowie .......
Old 04-10-2005, 06:42 PM
  #41
Ginge !
just finding my feet
Ginge !'s Avatar
i only use mobil 1 motorsport in mine, ive got a big wing sump too remember
but the point i was making is that the oil dont actually work a lower temps, sothe reason ya use it aint about
its the working property of it ( before it changes and works as well as treacle)
now if ya change the oil every 3k PLUS before track use ect then in normal fast road conditions on stage 3 engines i seriously cant see the difference with 3k semi synth and super delux red sticky touch stuff
well other than a oil salesman recomending it, hes obv the science part sorted,,,,,,,,,,,, doe he actually use a cossie engine,,,,,,,, a skyline engine ect
if not then what is opinion worth apart from the science facts, but didnt the scientists say the world was flat
id trust what a tunner says and in all honesty when stu set up my car he removed 100 quids worth of plugs for 10 quid cheepy plugs but never changed my oil
Old 04-10-2005, 07:33 PM
  #42
bud-weis
Football Cwazy
bud-weis's Avatar
that's cos he's rounded off your sump plug,have you used it since?
i get what ya saying
Old 04-10-2005, 07:56 PM
  #43
Ginge !
Ginge !'s Avatar
my point is dont always belive the hype
grs coolers where the best, then NMS, now pro alloy and allthe time the older ones then get a slating
my cossie aint moved at all since april. ill show ya be bank statments to prove it too
Old 04-10-2005, 08:12 PM
  #44
Blimey lads just read this lot, The Silkolene will be superior to Castrol, do i need it who cares. I change my oil regularily cos it helps keep my engine safe its no big deal & at little cost compared to my engine.
My oil is supplied free, but only because when I rang to order it they Knew who i was & said they would sponsor my oil. I would have made the change even if they had not made me this offer.
Mark first muted this change some time back & Rod Bell just confirmed that it was superior. Keith Cowie was also with Mark & i thought he had made the recomendation.
Rod
Old 04-10-2005, 08:16 PM
  #45
Ginge !
Ginge !'s Avatar
ahhhh so its a better oil as its a sponser
so could they not give ya castrol then
but rod in a nut shell you made the change for what actualy benifit ( apart from the cash advantage) seriously interested on what the castrol let ya down with to make the good change for the better
i will give you a ford air freshener that smells like roses, if i give it to ya FOC and keep suplying em will they be better too
mk3ste
17-10-2021 10:09 AM
gcfcos
59
06-10-2015 05:04 PM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
Marv888
26-09-2015 03:44 PM
Quick Reply: After advice from Kieth Cowie .......
