anyone fitted a "group A" strut brace
just finding my feet
think thats what there called anywaym the one that wedges in the strut tops on the inside
did you have to remove your suspention legs to get it on as its fooking tight in my car
phil i was thinking about getting it back in , cars all poly bushed meaning i gotta undo em as theres not much "give" in em
when i took it off the nuts just fell on the floor
supose theres 1 less item to polish
Originally Posted by Bosch-Man
...it aint that easy to take the strut out!
Unloosen the top nut on the strut,undo the bolt on the hub,slide it out, long bar and prise out the strut,bit of weight needed too , when popped out, undo the top strut bolt and its out.
Easy.
they are "easy" to do once youve done one, i aint the most mechanical person in the world but i pissed the near side after taking hours doing the off side (and trashing the brake line , needed replacing so i werent arsed )
no lever required, bottle jack the strut from the brake line mount once its loose in the hub (chisel it open a tad and wedge it open), how easy that is with the springs still on i dont know as id already chopped mine up with the grinder
PS why would you need to remove the struts to fit a strut brace
cant get me sausage fingers in cause th strut is in the way
longer than the last time he done it, he just folded the car overlast time i belive
eagle on a serious note its the easiest way to do work on a engine, thats how the boys at work do cam belts on landrovers
also a class idea ona erst too, taking the drive shafts out AFTER the engines out the car, easy
just need a wy to hold the car up hgh enough
ahh i get you now
im sure it will be do-able without removing completely though
i never removed the struts (wide ass springs....konis at the time) when i fitted my brace....
...and that involved getting 4 mahoosive nuts per strut on from underneath
awkward as fook but possible
bigluke200
14
02-09-2015 10:35 PM
155lee
14-08-2015 11:21 AM
RIB1122
12-08-2015 08:49 PM
track.focus'd
12-08-2015 05:53 PM
