water injection jets.. siz of thread and...
Dave,
Looks like it's M8 x 0.75
M8 x 0.75 Tap for water jet
Nickel plated brass water jet 0.4mm 4mm hosetail
Nickel plated brass water jet 0.5mm 4mm hosetail
Nickel plated brass water jet 0.6mm 4mm hosetail
Nickel plated brass water jet 0.7mm 4mm hosetail
Nickel plated brass water jet 0.8mm 4mm hosetail
Nickel plated brass water jet 0.9mm 4mm hosetail
Nickel plated brass water jet 1.0mm 4mm hosetail
Nickel plated brass water jet 0.4mm 6mm hosetail
Nickel plated brass water jet 0.5mm 6mm hosetail
Nickel plated brass water jet 0.6mm 6mm hosetail
Nickel plated brass water jet 0.7mm 6mm hosetail
Nickel plated brass water jet 0.8mm 6mm hosetail
Nickel plated brass water jet 0.9mm 6mm hosetail
Nickel plated brass water jet 1.0mm 6mm hosetail
M8 x 0.75 Blanking plug
http://www.aquamist.co.uk/sl/plist/frm-4.html
ian, not sure what jets to use... the best i guess. Wether these are aquamist or not I dont know
thanks doug, whose jets are those measurements for?
Dave,
I think I have some .8 and jets here I can sell you if you need em....as Doug says the thread is M8 metric fine.....
Give me a bell if you need 07866855738
Regards
Ian
Regards
Ian
Dave, I have a collar (made from billit alloy) I can sell you,
it's custom made and tapped to take two jets.........also have a pair of .8 jets to sell.....
Will post up a pic later.........
Mark RS
12-10-2015 06:01 AM
