Calling all breakers / DaveEscos / Ginge
Has anyone got the blanking plates that go in the corners of the bottom grill on the bumper of an Escort Cosworth?
See picture below - you can see, where they bolt to in corners where holes are...
Doug,
Prove it, as I got Martin to see if he could remove the ones off your car, but it didn't have any on it for him to do so
. Seriously, depends on what you want...
Phil,
I do indeed run a spoiler, but that was the only photo I had that showed the grill locations adequately and that was on one of the four occasions that I had broken it
. Seriously, depends on what you want... Phil,
Doug,
.................Seriously, depends on what you want...
Otherwise:
Silkolene Pro S 10W-50 - 5 litres
100% Synthetic Oil For All Race Engines. The ultimate 100% ester/pao synthetic high performance engine oil that provides optimum protection and extended engine life and reliability. It exceeds........................
Originally Posted by Bosch-Man
Doug have you got more pics of your Escos and what ET your wheels are?
The O.Z. 17" Superlites (magnesium) are normal Group A offset of ET35 mm so I need to fit spacers (10 - 12 mm and longer studs).....
Will post pics of the Es Cos in a few mins.
...i just feel mine need about 5mm spacers added to make them look right.
Pics will be good.
Pics will be good.
, but 'm not a breaker, Dave or Ginge
Doug nice but from that last pic dont you think the wheels need to be out more?
At the moment I have 9 - 10 turns of thread so if I fit spacers the wheel studs would have to be changed...............Hang on a min, I have to change the studs soon anyway to accomidate the 17" superlites........
Lol @ Phil, it wouldn't be up to the job
Don't remember any missed calls, PM or TXT me your number if it's changed..... might have had a call I didn't answer in time actually, 0131/4... ?? might have been you - apologies if it was.
...no not me...01622....
Doug...i am putting 5mm spacers all round without longer studs should be ok
Got offered a set of those in 16in magnesium complete with the wheel spacer kit a really nice wheel buit i really only would considser 18's as i just think its what the Escos has to have.
Mike.....if you look at my sig, vewy carefuwy..... LMAO
Phil, no not you then - dunno what happened, phone didn't say missed call - you sure you rang ME? LOL
What Peggy's never seen, she won't miss
Originally Posted by Billabong
Doug, those are what sits behind them and is for routing air to the brakes IIRC
a single bolt to the upper crossmember, each.. mine seized when i went to remove so i had to cut them out... i have these if you need them
poxy things flap all over the place though unless secured from below
Originally Posted by Doug Stirling
Mike, these are what I had on my car.................cant see what others have posted - pics 9on my dial-up) are taking AGES to load
