cossie spark plugs are these the right ones???
Old 26-09-2005, 03:40 PM
jaiscossie
jaiscossie's Avatar
Default cossie spark plugs are these the right ones???
got some new plugs yesterday from halfords for the cossie, needed some quick you see!!! in there book they listed ngk bcr8es for cosworth ... are these correct???
the car seems to idle and run better than when it had the old plugs in
Old 26-09-2005, 03:43 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I wouldn't use these in a tuned car. You should use the Ford AGP 071 plugs, cheap as chips and good for 200 to 600bhp .
Old 26-09-2005, 03:59 PM
jaiscossie
jaiscossie's Avatar
are these plugs likely to cause damage if there left in for a week or so then mate?
Old 26-09-2005, 04:00 PM
Mike Rainbird
Caraholic
Not in normal driving, just don't hold any high boost.
Old 26-09-2005, 04:01 PM
Toe Knee
Toe Knee's Avatar
Not if u dont rag the fuck outa it no
Should be ok if u run it off boost and dont cane it about poodling about, but thats never easy is it
Old 26-09-2005, 04:03 PM
jaiscossie
jaiscossie's Avatar
am i best off putting the old champion qc57c bk in till i get the ford ones then???
Old 26-09-2005, 04:07 PM
Mike Rainbird
Caraholic
If you have no will power, yes .
Old 26-09-2005, 04:08 PM
jaiscossie
jaiscossie's Avatar
i just dont want halfords crappy plugs to bugger my rebuilt engine lol ...dam you halfords dam you
Old 26-09-2005, 04:35 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
As above unless you want to spend more on a plug with more longevity and better cold/slow running, in which case, the Denso iridiums are unvbeatable.
Old 26-09-2005, 05:12 PM
CossieEdd
CossieEdd's Avatar
I used BCR8ES plugs in my first Cossie and it used to melt / blow the end off one about every other time I drove the damn thing (usually no.3 cylinder IIRC). Not sure molten spark plug tips would have done the pistons much good either, but I didn't know much about Cossie's back then and just kept changing them !
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: cossie spark plugs are these the right ones???
