cometic?
Old Sep 22, 2005 | 05:27 PM
righthooker's Avatar
righthooker
Default cometic?
Basicly where from and how much are they,been recomended by some pees as a good replacement? think i had one a few years ago ,are they the 3 or 4 layer steel one?if so i think mine lasted 500 miles
Old Sep 22, 2005 | 05:30 PM
Graceland's Avatar
Graceland
Team HOTHOT!
they are 3 layer steel with bore rings.
on the early gaskets, if the bore rings wern't lined up properly, the gasket wouldn't seal properly and would fail.
the latest revision of the steel gasket has the bore rings aligned on a thin layer of material between the steel sheets and therefore won't move out of place
all faces must be impecably clean and flat when fitting the gasket tho - or it won't seal and will fail
by far the gasket of choice tho - its what i'll be having on my new engine next year
Old Sep 22, 2005 | 05:31 PM
Graceland's Avatar
Graceland
Team HOTHOT!
also forgot to say, woodford garage sell them, as do pj motorsport and burtons - think they are about the 200 quid mark
www.cometic.com for a full supplier and application list
Old Sep 22, 2005 | 05:33 PM
righthooker
cheers gracey
Old Sep 22, 2005 | 05:57 PM
Turbo lag's Avatar
Turbo lag
I think mine has failed at less than a thousand miles
will take the head off and have a look to see what caused it.
Dave.
Old Sep 22, 2005 | 06:09 PM
Damo V's Avatar
Damo V
I had one fail, was the older type though when it properly went took the head off to find it had been blowing across the bores for quite some time.... WRC 4 layer or std YBP is the way to go
Old Sep 22, 2005 | 06:36 PM
righthooker
standard gasket Damo for a stg3 ,???? presuming thats a YBP??
Old Sep 22, 2005 | 06:43 PM
Damo V's Avatar
Damo V
Greeens sensible safe boost,,,.. IMO Yes, honestly I had a Cometic, on a freshly skimmed head recently rebuilt engine so As flat as possible block without decking, all lined up properly did about 5 or 6 k before blew into water gallery BUT HAD DEFO been blowing across the bores for some time
The reason I say the YBP item, is if you cant run to the cost of a gen WRC item...
Though having said that there are people who will suggest Cometic are MINT and have no probs... mine was fitted "dry" BTW
Old Sep 22, 2005 | 06:45 PM
Damo V's Avatar
Damo V
BTW she ran a "group a" item for some 20k with no issues till it went.
Old Sep 22, 2005 | 06:47 PM
Rhys's Avatar
Rhys
Cometic one for me is fine! Though i "heard" somewhere that its ideal to have longstuded block when running this? i have so not to worried.
Old Sep 22, 2005 | 06:48 PM
righthooker
had a group a when i bought it 4 years ago,dont know how long it had been on but i managed to shaft that one too.
What do you mean by dry mate??
Old Sep 22, 2005 | 06:53 PM
TIFF's Avatar
TIFF
Chasing Radders
No Comment
Old Sep 22, 2005 | 07:24 PM
Damo V's Avatar
Damo V
same old story different people have different ways of doing things... dry as in just like std or wet where you may smear some special stuff either side to aid sealing, I was told this by a well known tuner on this board... I would personally go with the latter option it does make more sense...
Old Sep 22, 2005 | 09:06 PM
daz1968's Avatar
daz1968
I have YB0611 on mine with std headbolts, been running upto 22psi on it with no trouble at all, and they are only about Ł60, it has done about 6-7k miles so far over about 5 years. This was just fitted dry and torqued as per manual.
Old Sep 22, 2005 | 09:11 PM
Damo V's Avatar
Damo V
daz1968, on what turbo ?
Old Sep 22, 2005 | 09:59 PM
G.Man's Avatar
G.Man
More like Ł100.... Ł200 will get you a full engine set
Old Sep 22, 2005 | 10:10 PM
dave cos4x4's Avatar
dave cos4x4
Have to have a word with Stu or Karl or the other out there.
i'm sure these to tuners will give you a better run down of the gaskets they suggest and use.
Dave.
Old Sep 22, 2005 | 10:31 PM
daz1968's Avatar
daz1968
Mines only on T3 set up by Karl, and when I rebuild my engine over winter am putting on another one and hoping this one is just as good, although I need 360 thrusts in my turbo as this is probably weak point as T3 is spinning fast to hold this. But I cannot see how turbo can effect gasket life.
Old Sep 23, 2005 | 07:51 AM
Damo V's Avatar
Damo V
Reason I asked is, as I understand it.....22psi on a T3 aint the same as 22 Psi on a T3/04
Old Sep 23, 2005 | 08:06 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
PJ Motorsport are doing fantastic deals on the new generation Cometic gaskets at the moment...
Old Sep 23, 2005 | 09:08 AM
SapphyMike's Avatar
SapphyMike
I am told that the block has to be decked to get it completely flat, as with it being a steel gasket, it doesnt help mask the imperfections like a fibrous gasket, such as a YB0611 or the now defunct YB01261 gaskets. The head also needs to be completely flat too.
The same applies when using the Ł400 Mountune gasket.
Old Sep 23, 2005 | 09:15 AM
JamesH's Avatar
JamesH
Old Sep 24, 2005 | 12:55 PM
righthooker
ordered a ybo611, that lasted the longest and i dont fancy having to do it again becaous of minute imperfection in the block.If it has any that is?
Old Sep 24, 2005 | 01:02 PM
Ginge !'s Avatar
Ginge !
just finding my feet
small turbo escos head gasket is the same as a group A and some even claim its cool upto 400bhp
when i take the head off mine im gonna go small turbo escos by victor reinz( or how ever its spelt ) the seem to last well for some reason
Old Sep 26, 2005 | 10:48 AM
SapphyMike's Avatar
SapphyMike
I tried to order one of these from Woodford recently - they dont have any left, and if they did, would be Ł120, compared to Ł60 ish for the YB0611 gasket..
They told me that they are no longer made..
I would imagine you'd have trouble getting one, unless you know of a source!
Old Sep 26, 2005 | 11:11 AM
Ginge !'s Avatar
Ginge !
mike the victor reinz one IS a ford gasket, thats who make em, try burtons/pj motorsport for em too
Old Sep 26, 2005 | 11:15 AM
SapphyMike's Avatar
SapphyMike
i know its a ford gasket!
like i said, thats what i was told, but looks like burtons do have the YB01261's in stock according to their website!
oh well, live n learn!
Old Sep 26, 2005 | 11:16 AM
Ginge !'s Avatar
Ginge !
you ned to be a tight fooker like me, ill search the world to save 20p
usually spend 20 quid in postage too to save the cash
Old Sep 26, 2005 | 11:29 AM
SapphyMike's Avatar
SapphyMike
LOL
If i need it, and its ok, i'll pay it LOL
mcgoo
Apr 9, 2005 10:20 PM
the strut brace
73
Mar 2, 2005 07:21 PM
bill
Feb 7, 2005 01:34 AM
gurnE
24
Jan 24, 2005 04:10 PM
