cam cover bolts how tight???
just got a new cam cover gasket as taking cam cover off to be powder coated. got some new stainless bolts but unsure of how tight to do these?? are there any tricks when replacing the cam cover gasket i should know about? cheers in advance guys
Team HOTHOT!
make sure the gasket is perfect on all faces, and that all mating surfaces are clean.
tightening the bolts - hand tight and then off the top of my head, they are 10 nm on a torque wrench
Team HOTHOT!
my prefered method of tightening is using a Tbar allen driver (5mm allen key it is) and doing them all tight with that - no chance of stripping the threads then
Football Cwazy
just had to do this myself, tis fairly easy, i used a small allen driver t-bar like above. i just nipped them up and then went round in a sort of seqeunce ( doing opposites ) . that was using a cometic gasket though, which is re-useable and seems much better than the ford jobbie
so you cant over tighten them and crush the gasket then? i will get those half moon seals aswell .at the moment when you give it some oil drips onto manifold and gives typical smell inside the cabin
cheers damo ill be carefull when doing them up then, saw your car at essex meet this month and fell inlove its a credit to you mate
rog
04-09-2015 07:24 AM
