secondhand block, different big end caps and line boring Q !
Say i have a second hand block without its original big end caps but i do have a set of end caps originally from another engine.
both 205 block based and used. I also have a crank that was from neither engine originally
would it be best to get it line bored or would i be better off buying new or ....
any info appreciated
If you use different caps have it line bored and it'll be good as new. I know builders that will line bore caps even if they came with the engine cause they can get them closer to perfect.
James Porter
28-10-2015 12:17 PM
