Running Problems, anyone help??
Old Sep 4, 2005 | 08:07 PM
matts1's Avatar
matts1
Default Running Problems, anyone help??
Pug 306 1.4 petrol, just had head gasket done and now ticks over uneven, sputters and has no power and cuts out, but sometimes run fine!
Any thoughs as to what could be causing the problem??
Thanks
Matt
Old Sep 5, 2005 | 12:25 AM
NUTS RuS's Avatar
NUTS RuS
Sounds like a sensor plug or air pipe maybe off or loose somewhere.
Old Sep 5, 2005 | 08:37 AM
matts1's Avatar
matts1
More info, It does it when you start it and go to pull away(hot or cold), chugs 3 times (sometimes cuts out) then runs fine.
Will check round to make sure everything is on correctly.
Anyone narrow it down at all???
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
